Jammin SCRT10 Thread >
Old 02-12-2010, 12:55 PM
  #1636
Scarab's Avatar
Originally Posted by marksp View Post
The Novak ESC folks are referring to "going up" is the HV Pro ESC, which has a high failure rate. The newer Novak Havok Pro should drive your HV4.5 motor just fine.
Good to know. I didn't realize people were referring to an ESC other than the NOVAK HAVOK PRO.
Scarab
Scarab is offline
Old 02-12-2010, 01:50 PM
  #1637
Company Representative
Default FYI
The Havoc Pros have basically the same performance (same on-resistance) as the GTBs and SLYDRs. So these earlier controllers can also be used with the HV Pro 4.5 motors (they always were compatible on 2S.) The Havoc Pro programming offers a few additional options over the other escs, but the HV 4.5 is the same motor we sold before.
A lot of the problems we experienced with the HV 4.5 systems were due to racers using them incorrectly, or using them in 1/8th /4S racing. The 4.5 motors were never suitable, or advised, for 4S racing applications. So, we removed them from distribution.
NovakTwo is offline
Old 02-12-2010, 01:54 PM
  #1638
gcosio's Avatar
Originally Posted by NovakTwo View Post
A lot of the problems we experienced with the HV 4.5 systems were due to racers using them incorrectly, or using them in racing. The 4.5 motors were never suitable, or advised, for racing applications. So, we removed them from distribution.
I feel dumb for asking but, When you say never suitable for racing applications, you mean on anything above 2s?
gcosio is offline
Old 02-12-2010, 01:56 PM
  #1639
Scarab's Avatar
I was thinking the same thing when I read his reply. My intent when I bought this as a combo from Nitrohouse was to race it.
Scarab
Scarab is offline
Old 02-12-2010, 02:02 PM
  #1640
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 105 (100%+)
Does anyone know the dimensions of the battery tray?
So I can figure out what will fit, thanks!
thecman26 is offline
Old 02-12-2010, 02:10 PM
  #1641
z50king's Avatar
Trader Rating: 14 (100%+)
its a strange battery tray. i dont know the size, but it sits the battery on its side. i assume work will have to be done on it to get most lipo battery connectors to come out of it. its weird
z50king is offline
Old 02-12-2010, 02:22 PM
  #1642
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Scarab
I assume he means on 4s. They are awesome for racing on 2s.
They're listed in this thread somewhere. I don't remember them off the top of my head though. Maybe try a thread search.
Actually the tray is designed in a way where most connectors will work. It has some big slots at on the sides at the back so even batteries with built in bullets will fit without a problem.
JAMMINKRAZY is offline
Old 02-12-2010, 04:58 PM
  #1643
team green's Avatar
For all you guy's running the Tekin RS pro with the Novak HV 4.5. What settings are you guy's using on the ESC?
I'm running a Speed Passion 3.5 and I don't want to fry my RS....
team green is offline
Old 02-12-2010, 05:14 PM
  #1644
I know that the Slash 4x4 are bad about throwing dirt up in the chassis, How
is the Jammin?
reddishdsb is offline
Old 02-12-2010, 05:25 PM
  #1645
Tilden's Avatar
Questions?? Question about ESC speed
Tilden is offline
Old 02-12-2010, 05:26 PM
  #1646
is the Jammin?
It kicks some dirt up, but the tall side guards keep most of it out of the chassis.
Old 02-12-2010, 05:29 PM
  #1647
Originally Posted by Tilden View Post
Would this be okay for HV 4.5 motor with HV Pro High-Voltage Brushless ESC and 2s lipo 35c?
You don't want that ESC. You need a 1/10 scale ESC designed to operate on 2s. I would HIGHLY recommend the Mamba Max Pro, or the Tekin RS pro. If you are looking to stay with novak, the GTB or Havok Pro would be a better option.
Old 02-12-2010, 05:38 PM
  #1648
I am re-posting my comment from above that I have edited for clarification. The "racing" that I was referring to was 1/8th scale on 4S.
NovakTwo is offline
Old 02-12-2010, 07:02 PM
  #1649
gcosio's Avatar
Good. You had me worried for a sec.. Just got my HV 5.5 and am planning to have first run this weekend.
gcosio is offline
Old 02-12-2010, 07:10 PM
  #1650
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Here's a link to a comprehensive oil viscosity table - http://www.twf8.ws/php/index.php?opt...per&Itemid=175
They don't publish their findings with what temp the tests are done.
Racecrafter is offline
