SC10 stability
Old 07-30-2009, 06:00 PM
Default SC10 stability
What some things can i do to my sc10 to make more stable? Your tips will be greatly appreciated!
allen71457 is offline
Old 07-31-2009, 10:12 PM
what do you mean "more stable"? is it crashing and rolling over? are you bashing around the street or are you on a track?
wheelhaus is offline
Old 07-31-2009, 10:18 PM
traxxas_trucks's Avatar
Toe out 1 degree
traxxas_trucks is offline
Old 08-01-2009, 09:54 AM
R40Victim's Avatar
Goosebump tires on the back only,(stock tires up front) and 2K weight Losi diff oil. Now my truck has a push, making it very easy to drive.
R40Victim is offline
Old 08-01-2009, 10:44 AM
Ephidelt490's Avatar
Trader Rating: 17 (100%+)
Try 10 wt AE shock oil in the rear diff
Ephidelt490 is offline
Old 08-01-2009, 09:49 PM
OG RC 10T's Avatar
Trader Rating: 41 (100%+)
http://users.telenet.be/elvo/1/1_content.html
This is an excellent source, click on the GO over on the right, and start reading.
OG RC 10T is offline
Old 08-01-2009, 10:01 PM
-J-
-J-'s Avatar
Trader Rating: 16 (94%+)
Originally Posted by traxxas_trucks View Post
Toe out 1 degree
You mean toe-in! Toe out will make the problem worse.
-J- is offline
Old 08-01-2009, 10:20 PM
RcRacing4Ever's Avatar
yea I got that losi rear hub thing going on with mine...2 degrees (in ward toe...), truck is pretty much planted. I also have 3 oz. of weight in the rear batt compartment with a lipo pack in the stock batt location with 2 oz. up front to help with the stearing transition. Its like driving a touring car on dirt with being able to break loose the rearend at will to get that drifting thing going around certian turns... If ya know what I mean
RcRacing4Ever is offline
Old 08-02-2009, 10:41 AM
excellent !!!
rc_cal is offline
Old 08-02-2009, 10:46 AM
tennvol11's Avatar
Trader Rating: 8 (90%+)
+1 on the Losi hub mod, I did that and it worked out great
tennvol11 is offline
Old 08-02-2009, 12:16 PM
BuggyKing's Avatar
Well toe angles effect more for entry and exit for cornering. For more stable you will length the wheelbase. And depending on track you run for example pistons and oil in shocks will also effect stability as well. Droop or down travel will also effect stability too.
BuggyKing is offline
Old 08-02-2009, 01:14 PM
Yes thank you for the correction
Old 08-02-2009, 01:59 PM
-J-
-J-'s Avatar
No problem. Just didn't want him to dial in some toe-out thinking it was going to be easier to drive!
-J- is offline
