deans mini plugs
deans mini plugs
i have some mini deans plug there the red ones and it has 2 sticking out of one side and 1 on the other ,i getting rid of my cheap loose connectors on my power switch for my nitro theres no postive or neg on the plug on the mini plug im thinking just solder the two battery wires and the other plug the same
it shouldn;t matter either way for an on off switch either its closed or its not
You have to solder the Rx side and battery connector "opposite". The single male plug will have to go into a female plug on the opposite connector. I like my + battery wire to be a female plug. So, battery + would be soldered to the side where connector is female, - would be soldered to the side where the single male connector comes out. For the Rx connection, - would then have to be soldered to the side with female connector, and + to side with single male connector. It's best to solder them with the plugs connected so they don't melt/warp. Get the iron on then off as quickly as possible. You'll also need to solder an adapter so you can charge your battery.
dont use deam plugs they suck
the only ones that wil fit through my recever box is mini deans
