i need help, bad
Old 07-20-2009, 11:12 PM
fr0z3nfr0g's Avatar
Default i need help, bad
ok so i just put the slydr system in my rc10b4...re manufactured, and all they had was the gtb spread spectrum, so i went for the slydr. same thing, more adjustments.
so now that im done explaining myself, i have what seems like an interference problem. dont know if its the brushless system interfering with the reciever, or the esc. but it never did it with the brushed system.
what happens is it seems to run on. when i hit the throttle sometimes it decides to go full throttle, even when im off the gas. and when i engage reverse, and i hit reverse, it goes backwards for a 10th of a second then forewards for a 10th of a second.
i was running a futaba 73 Mhz radio, then switched to an associated 27Mhz, and i even unsoldered the wires goin to the motor and twisted them so that it would hopefully cancel out some interference. please help?!?
fr0z3nfr0g is offline
Old 07-21-2009, 07:43 AM
Onetrade's Avatar
Trader Rating: 14 (100%+)
Try reseting the ESC. When you first install your esc you have to set it to the radio you are using, if you change the radio or transmitter then you have to reset the esc.
Onetrade is offline
Old 07-21-2009, 08:16 AM
fr0z3nfr0g's Avatar
i have tried 2 different radios, programmed both of them
Old 07-21-2009, 08:20 AM
whitrzac's Avatar
Trader Rating: 96 (100%+)
sensor wire pluged in>??
whitrzac is offline
Old 07-21-2009, 08:21 AM
bcrazy's Avatar
Post your concern here. Novak representatives are on this thread regularly and may be able to help you out
http://www.rctech.net/forum/electric...sion-kits.html
bcrazy is offline
Old 07-21-2009, 08:25 AM
fr0z3nfr0g's Avatar
sensor wire is plugged in, and ill try the novak link
