EZ-RUN 1/8 motor????
anyone ever used one of these, i was looking at getting the 2300kv motor to use with my MMM esc, just wanting some feedback, i used to use there 1/10 motor and had NO problem out of it, just wondering about the 1/8 motor?
Thanks before hand
Daniel
Thanks before hand
Daniel
Yeah I have the EZrun 80A combo which comes with the 2350kv motor.
On 4S it is very fast and reliable. It doesn't get overly hot under normal conditions.
However, on 6S, you'd likely blow it up. From what I've heard, the 2350 motor is not happy due to the fact that it is spinning at a very fast rate of knots with 6S.
The 2300kv motor might be a little better on 6S, but I'm not sure.
If you only run 4S you should be fine, or probably also fine on 5S. It is reliable, and completely cog free, on the EZRun, don't know how it'll be on a MMM.
Here is a video of my emaxx using the said motor and ESC on 4S.
http://www.youtube.com/watch?v=ot4Jk3ocRXw
R/C Tech Elite Member
I am running the same set up you are talking about the MMM ESC and 2350kv EZrun motor and it works GREAT so far i ran it last weekend and the guy who help me built it runs a Neu motor and liked my motor and said the power was good.And i am running a Flightpower 4s battery and it runs great temps just right and i ran it for 15min and the battery was only down to 14.3 when i went to charge it.
