Convert SC10 to 12mm hex?
Hey everyone. I've stripped two rear wheels and want to switch my SC10 over to a 12mm hex. I've been searching for something to convert the front to 12mm but I haven't found anything yet.
Are there some interchangeable parts from other brands or trucks or even some kind of kit that would work? Any help is appreciated. Thanks!
Nothing?? Come on, there has to be something I can do.
Thanks guys, but I'm looking for something for the front.
I just bought an SC10 and I am going to run it in our stock slash spec class. I was told I could do this, if I ran the slash stock servo, esc, titan motor, and tires.
For the rear, I just stuck the slash hexes over the pins and then used the slash tires.
The fronts were a little trickier. I used the slash knuckles, but I had to drill them out to the size of the SC10 hinge pins. After this, I could use the slash bearings, axle, hex, etc. to mount the slash tires.
The one thing that I noticed by doing this is that the front wheel width was wider than the rear. I then switched the hexes so that the slash fronts were on the SC10 rear and vice-versa. This helped and now they seem close to the same width.
I have not raced this truck against other slashes yet, so I can state if it is better.
tim
tim
