Clutch Disengaging >
Clutch Disengaging
Clutch Disengaging
Old 06-24-2009, 12:54 AM
Suspended
Default Clutch Disengaging
I am running an OS .28 in my Losi 8 Truggy. My truck made a weird metal claning noise when I was running it. After inspecting the clutch the bolt that goes over the flywheel losened up. Any idea on what would cause this? I even used loctite.
snowboarder0322 is offline
Old 06-24-2009, 06:42 AM
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Locktite again and let dey! Make sure your clutch is fresh! Bearings, pads, springs! Check the bell for cracks!
XXXDad is offline
Old 06-24-2009, 06:53 PM
Trader Rating: 21 (100%+)
When loctite fails, theres usually oil or grease involved - either prevents loctite from either setting (worst case) or developing full strength. Use something like motor spray to clean everything before applying loctite. A good flywheel wrench is key to holding it so you can really generate some torque when tightening the clutch nut.
Duster_360 is offline
