Need B4 rear tire recommendations please
I found this new track that I plan on racing it more frequently, but the last race there with my B4 was a disaster. I don't have many tire options in my arsenal at the moment, but the one's I tried on this track might as well have been slicks
My B4 is being run in the mod class, so I have a 6.5 brushless motor with a 2C Lipo.
This track is located in a warehouse, so they use real dirt (not clay) on top of cement. They water the track between rounds, but because the dirt sits on top of the cement it doesn't hold the moisture for long. The dirt is loose, but not loamy. For the most part the track is smooth; no studder bump sections. There are no real big gnarly jumps, just a few well placed timing jumps that are relatively small. The last turn is a wide arc that transitions well into the straight away which creates a fairly long section of high speed. I'd consider it low/medium traction when dry, and medium/high traction when wet. I really only had some worn down hole shots and taper pins, and I mean they were really worn down. I tried them when the track was dry, but didn't get a chance to try them when it was wet. When the track was dry the hole shots and taper pins made the rear end loose. I also tried goosebumps which were decent when the track was really dry and the dust started to accumulate. I used 4 groove directionals in the front.
I plan on picking up up two sets of new rear tires for the B4, and given the above track description I was hoping for some recommendations.
Suspended
Where is the Track Located "California" sounds like my home track,anyways when the track is slighty wet.dusty Blue Bar Codes By JConcepts..When track is swept and watered Try pink taper pins..Or Silver Tapers on Rear Spray with Motor Spray.....
The 6.5 may be overpowering things. You probably will be ok with something like Holeshots or Bow Ties - but the motor and gearing should be talked about first. What's the track size of the longest straight and your gearing?
You may want to try an 8.5 or 10.5 motor if it's not a big track. Or gear the 6.5 really low (using the 87 spur not 81 stock) and try that.
Gear it low - the other way. Say 17 or 16T pinion to start. Low will let you not put as much tire-spin into the wheels and maybe have a little more touch coming out of turns (also lower your radio's Throttle exponential too if you have it). Higher gearing is bigger pinions. Also, check your Slipper setup. Could be it's too tight leading to wheel spin especially with a hot motor like a 6.5
