Does speed control regulate power?
The speedo gives a constant 6 volts to the receiver which in turn gives the servo 6 volts. The only way to that it will send more power is if you run an external BEC. The speedo prioritizes the receiver over the motor most if not all the time. Only time that it does not is when the motor draws too many amps for the battery to supply.
Nick
Nick
