Cooling motor off >
Cooling motor off
Cooling motor off
Old 06-19-2009, 09:05 PM
SirJangly's Avatar
Trader Rating: 14 (100%+)
Default Cooling motor off
Just curious, I want to race stock slash at my lhs, and was curious as to what my options are in regards to cooling my motor off between heats. I know I can just let the air cool it, but are there any faster means? I was thinking of maybe a heatsink to apply between heats, or, well, no idea. Thanks in advance guys!
SirJangly is offline
Old 06-19-2009, 09:12 PM
Heatsink would work, maybe chill the heatsink on ice before you use it, if you need to chill it fast.
howtowakeakar is offline
Old 06-19-2009, 09:13 PM
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
A regular fan will cool the car, ESC, and motor rather quickly. I set my 1/8 scale near a fan someone brought to the track to cool them self off in the pits and the motor cooled 5x faster than normal.
rearviewmirror is offline
Old 06-19-2009, 09:35 PM
SirJangly's Avatar
Well I have never raced before. Are heats usually one after the other, or does each class go through their first heats, then after that everyone does their second?
Old 06-19-2009, 09:39 PM
Yeah.. there's plenty of time between heats. The track RD will rotate through all classes so you'll have plenty of time. The only time you'll have to race back to back is if you bump from main to main, in that case you won't have time to cool anything.
Old 06-19-2009, 10:29 PM
SirJangly's Avatar
Ah that would suck, although I'm sure the titan could handle it if I lower my pinion, which I should, right? On a track with jumps and many turns, wouldn't you want the extra acceleration versus topspeed? Also, can I have a link to the heatsink that was discussed earlier?
Old 06-19-2009, 10:30 PM
SirJangly's Avatar
I forgot to say thank you so much for all the information given so far
Old 06-20-2009, 04:28 AM
tom_chang79's Avatar
I just bring one of those circular fans that's very squat, where you can angle it up and down. I point the fan upwards and just set my car upside down on it (watch your antenna tubes!).
Or, you can just have it point towards you and just stick your slash sideways, on two wheels, and let it blow your ESC and Motor.
tom_chang79 is offline
Old 06-20-2009, 01:16 PM
Trader Rating: 21 (100%+)
..... Also, can I have a link to the heatsink that was discussed earlier?
Has a fan as well, but can remove to use just heatsink -
http://www.integy.com/st_prod.html?p...32&p_catid=109
Duster_360 is offline
Old 06-20-2009, 01:36 PM
SirJangly's Avatar
Do I have to take the motor out, or can I leave it in when I use this?
Old 06-20-2009, 02:04 PM
Brushlessboy16's Avatar
Trader Rating: 18 (100%+)
get a can of computer dusting spray, flip it upside down and spray it on the motor. thats as fast as you will cool it.
Brushlessboy16 is offline
Old 06-20-2009, 05:23 PM
No, this slips on over the end of the can, no need to take motor out.
Old 06-20-2009, 05:46 PM
shinta's Avatar
i dont race off road all that much any more. but i know when i was racing i have a heatsink with fan and i got a small battery and wired it up to it. once the heat was over i just slipped it on and turned the fan on and when about checking charging battery's and what not and just took it off before the race.
shinta is offline
Old 06-20-2009, 06:11 PM
OG RC 10T's Avatar
Trader Rating: 41 (100%+)
You can always dip it in ice water
Seriously though....
The motor shouldnt be getting that hot, to be of a concern, during a normal timed run or amain.
If it is getting hot to the point of concern, you should probally lower the pinion by a tooth or two, to make sure it doesnt overheat.
Your least expensive route would be to bring a small electric cooling fan, like you find at walmart, and put the truck in front of it between uses.
OG RC 10T is offline
Old 06-20-2009, 06:13 PM
OG RC 10T's Avatar
oh...
Also if you cool it off too quickly, as with a motor or electronics spray, the transition from hot to cold quickly, can cause the magnets and or brushes to crack and break.
