why does my traxxs slash motor keep getting hot after im done driving it >
Old 06-18-2009, 05:30 PM
Default why does my traxxs slash motor keep getting hot after im done driving it
ive chaneged the pinion and spur gear to fit the right need for it and ive meshed it right but everytime i get done the motor is hot and also its the stock motor that came on it
Leroy1234p is offline
Old 06-18-2009, 05:32 PM
sLaSh It UPP's Avatar
what is your gearing?
sLaSh It UPP is offline
Old 06-18-2009, 05:37 PM
well i have these setups
i got 18 19 and 23 pinions
and 83 86 and 90 tooth spur gears
right now i got 23 pionion with 90 tooth spur gear which one is the best setup and why is the motor gettign hot after each run
Old 06-18-2009, 05:49 PM
How hot is hot? I mean, is it hot on a thermometer or hot on the hand?
Human is offline
Old 06-18-2009, 05:52 PM
hot on the hand where i cant even touch it
Old 06-18-2009, 05:58 PM
just run stock 18/86
Old 06-18-2009, 06:01 PM
i like to race and bash so would that be a good setup and also it doesnt seem that fast when i use the 18/86 setup
Old 06-18-2009, 06:07 PM
Trader Rating: 20 (100%+)
i use 22 or 23 pinion and a 86 spur for racing. I have been on the track for over 10 minutes and its not too hot. I do not bash but it does depend on the surface you are running on. loose loamy dirt, grass, sand etc...
how long are you driving for and what surface?
215slowpoke is offline
Old 06-18-2009, 06:09 PM
im running on grass,dirt,rocks,and etc and also i run till the battery is almost dead and also the battery is a 5200amh lipo
Old 06-18-2009, 06:18 PM
GSRswapandslow's Avatar
Trader Rating: 22 (100%+)
3s lipo needs to be geared like 15/16t pinion with an 86 or 90t spur.
i have a 6400mah 3s on mine and had to keep gearing down and down.
but, as for grass...you run in grass and you WILL kill your titan. that puts way too much stress on a slash. if youwanna run in grass, at least get a pede
GSRswapandslow is offline
Old 06-18-2009, 06:21 PM
well its kinda hard not to run in the grass cause thats all thats around me
Old 06-18-2009, 07:31 PM
CClay1282's Avatar
Gear down when your bashing and running the whole pack out on it. Then gear up a little when you go racing. Keep the motor at about 120 or less and your motor will last longer.
CClay1282 is offline
Old 06-18-2009, 09:39 PM
you need a different rc then, sorry
slash's are NOT made for the grass. if you gear WAY WAY down, then you'll keep from killing your motor too terribly fast, but it's still not ideal
Old 06-19-2009, 04:30 AM
Ffejdat's Avatar
The other option here is, keep running it just like you are, maybe not so long at one time, don't run the battery down quite so far, it's not good for lipo. If the motor is still working, so what, sometime you will kill that motor, then just get another one, they are fairly cheap. Your combo of gearing and where you run is what's making all the heat, but so what if it's working and nothing is melting or burning, have fun with it, that's what it's for! Maybe you could get a clip on haetsink for the motor of some kind....
Ffejdat is offline
Old 06-19-2009, 05:39 AM
jmcvicker's Avatar
No grass. No grass. It's like having 4 seized bearings in the wheels.
jmcvicker is offline
