T-maxx set up help?
Hi,
I was wondering if anyone could help me out with a good set-up for racing a T-maxx on an off road track? The track is well groomed and nothing too crazy as far as size of jumps. What shock oil, and mounting positions do you guys recommend? Also springs and gearing, and anything else helpful would be appreciated. Thanks, Brad |
Well Brad,
what you can do is move,the front shocks out on the top (2-3holes),and move the back shocks out 2 holes on the bottom,...........This will let you too go into the turns quicker.Now go too gree springs all around...because the stock setting is just too too soft.You should go to 85weight shock oil,so now every time you touch the breaks...,it will not slump down..........also more stearing,.............and you will be able to get out of the corners nice and fast. by. not slow!... -ty-x-ray racer |
