What s battery are most 1/8 buggies running
I'm getting ready to buy some packs but I don't know if I should get 4,5, or 6s. My ESC can handle 6s.
I don't know if its better to go 4s with a higher kv motor or 6s with something like 1400-1700kv.
One thing I am sure of is I want them all the same s rating so the car drives the same with each pack.
As the summer progresses, more and more people will be wishing they chose 6S and a 1500kv motor (or lower).
The more cells you chose to run will inevitably be more efficient and cooler running. So if you are starting to chose equipment now and already have a ESC capable of running 6S, then go with 6S.
Packs are getting lower and lower in price and quality seems to be getting better at the same time. Check out some of the newer Nue packs. Soon, a 6S pack will cost less than $100 each (here in the US) and it will be a good day!
Don't try to go with anything more than a 1500kv motor with 6S if you are trying to race.
Pretty much all the guys running Caster cars are doing 4s, because of the layout of the car... built to run standard 2s ROAR type packs. I also ran 4s with my other cars before the Caster.
4s and 1800-2000 is a proven setup that I've run for several years without a problem even in the summer heat.
But I agree that voltage is your friend, and 6s is a good thing if you choose the correct motor. I have a pair of 3s packs and 1300kv motor, and it seems to run very well but I haven't run it much yet. I'm wanting to try racing it sometime soon, but not as a permanent change.
Right now my favorite 4s race (lightweight) setup:
Caster Fusion Pro
Mamba Max Pro
Neu 1509 1.5y 1820kv
Maxamps 2s 4200 35c packs
geared 44/15 (43/13 diffs)
about 7.5lbs w/JC body and Panther Boas
Caster Fusion Pro
Mamba Max Pro
are there any guidelines in place for this, or likely to be coming along? or do you just work off not hitting the max rev limit of a motor and go from there?
eg will there be classes that require a 4s limit?
edit: Just looked at the ROAR site - 1/8 buggies seem to have a 4s lipo limit for batteries.
re: KV vs input voltage...
I had a cheap 1100kv motor from overseas for my first try at an E-1/8th and it was dirt slow on 4s as you can imagine. So I got both 4s A123 packs under 12.5 volts and then put them in series to the MMM esc = 25volts
Still the motor was quite warm after 10 minutes... but just as fast as the 4s/2200kv combo.
I like the idea of higher volts/less kv, but fitting high cell counts with A123 is a pain
AE RC8E with two 2S 5200mah 40C packs
FT RC8e with two 2s Reedy 35C 5000 packs, but that will change when Reedy comes out with their 4S brick pack.
