Sphere help
Old 05-24-2009, 06:10 PM
BSS
BSS's Avatar
Trader Rating: 16 (100%+)
Default Sphere help
i bought a sphere recently and something is up with it. one of the guys at my track set it up and it worked fine for the first 2 weeks. now this week when i turn it on, the motor smokes and the sphere gets very hot in like seconds. it did this a week ago, but i turned the car on/off and that fixed it. Now something is wrong with it and my motor now. any thoughts? i checked everything and found nothing touching or loose
BSS is offline
Old 05-24-2009, 06:23 PM
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
you connect it backwards to the battery ? buy it used ?
Jason Pelletier is offline
Old 05-24-2009, 06:37 PM
BSS
BSS's Avatar
bought it from rob, everything was connected correctly *deans*
BSS is offline
Old 05-24-2009, 10:03 PM
jnslprd's Avatar
was it the one rob plugged in backwards but didnt smoke?
jnslprd is offline
Old 05-24-2009, 10:07 PM
BSS
BSS's Avatar
it was new
BSS is offline
Old 05-24-2009, 11:15 PM
jnslprd's Avatar
that sucks i have 2 to send in also, it suck that they work soo well when they do work.
jnslprd is offline
Old 05-25-2009, 06:20 PM
what motor were u using and what was the gearing.
what battery were you using as well.
Old 05-25-2009, 07:16 PM
Is it a Sphere Comp with the auto Brushed/brushless motor sensor?
If so did you try to run it when the sensor wire was disconnected? If the sensor wire wasn't hooked up the speedo thought it was a brushed motor and sent power down 2 of the motor wires at the same time which prety much instantly fries the motor. The Speedo might be OK though.
Bike racer is offline
Old 05-25-2009, 07:34 PM
rcmark24's Avatar
Trader Rating: 14 (100%+)
No I think LRP is having some problems. I bought a new SPX last week. Plugged it in for the first time without a motor hooked up and it went up in smoke in less than 10 sec. No the battery wasn't hooked up wrong and I didn't even have time to start programming it. I've owned over a dozen LRPs and have never had any problems until now but I have seen some of my fellow racers have similiar problems.
rcmark24 is offline
Old 06-20-2009, 09:37 AM
BSS
BSS's Avatar
Bump, I sent the sphere back to LRP but the guy there didn't find anything wrong with it. Everything was plugged in correctly, I bought another 10.5 thinking that my motor was bad, but it went up in smoke in seconds. I'm stumped
BSS is offline
Old 06-20-2009, 10:23 AM
Tech Legend
Wild Cherry's Avatar
Sounds like a bad motor ..
Wild Cherry is offline
Old 06-20-2009, 10:29 AM
BSS
BSS's Avatar
Why would it be a bad motor? The first one burnt out and I thought it was a bad motor, but I bought another NEW 10.5 from orion and that one burnt out too. Once I turn the switch on, the motor smokes instantly. ALL the wires are hooked up correctly.
BSS is offline
Old 06-20-2009, 10:34 AM
Tech Legend
You just said the ESC checked out ok , so it has to be the motor ....
Borrow a motor that you know is Ok and check again...
Old 06-20-2009, 10:42 AM
Suspended
Cool AE Is Killer Of All......
Let someone that knows what there doing look at it .....
losidriver70 is offline
Old 06-20-2009, 11:05 AM
BSS
BSS's Avatar
Whats that suppose to mean
BSS is offline
