CastleLink setups
CastleLink setups
ANybody care to share their setups in CastleLink for their 2WD off road trucks? Be sure to specify what ESC/motor combo, and battery..
T4
2S Lipo 30C,
Mamba Max
5700kV
Punch control 40%
Throttle Curve, dragged down 10% on Y-axis at 50% of x-axis.
Drag Brake 20%
Brake 50%
Motor Timing default
Paul has castle link on the lap top on the back track, so if you need to make changes between qualifiers it's pretty quick and easy.
Yea, I finally able to get my Laptop working so I could use XP to run the software. I havent had luck trying to tune it using the transmitter, so hopefully playing with the curve a bit will help.. Thanks bro, almost identical setups
