mamba
Old 05-23-2009, 09:39 PM
gholt13's Avatar
Default mamba
can a mamba be geared to low that the motor would overheat?
gholt13 is offline
Old 05-23-2009, 10:50 PM
Yes it can. If your lucky, the ESC will go into thermal protection and shut everything down before you do major damage..
NitroVal is offline
Old 05-23-2009, 10:54 PM
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
There is NO temp protection for the motor, only the ESC can thermal. So for the first few runs check your motor temp. I like see mine no more than 140 degrees, although when the ambient temp is higher the motor will be slightly higher. If you've no temp gun then test with your hand, if you can hold your hand on it for over three second after a long run it should be fine. Basically if your hand can handle 150 degrees or so, any hotter and you won't be able to hold it for three seconds.
rearviewmirror is offline
Old 05-24-2009, 06:13 AM
sLaSh It UPP's Avatar
yeah you can but your esc will shut down protecting it form damaging itself
sLaSh It UPP is offline
