Speedpassion ESCs for 1/10 scale racing
#18
Per SP info for turn to kV rating, the shortcourse is between a 9.5 and a 10.5. That's more than enough power for a shortcourse truck. I raced my Slash with a SP 13.5 AND that was more than the tires/track could handle!
Be sure to power what ever BL you get with a 3200 and up lipo, without lipo power you won't know how much power you have! Really!!!!
#19
With what I've seen and drove (my race team partner has the 3000kV in his Slash) the sensorless motor isn't a problem.
Ok thanks for that i have never run sensorless but for the price compared to a Novak Havoc system and the optional USB tuning interface it looks like a good system.
Now it's not stated but does this ESC have LIPO cutoff???? the S/P web site says it supports 2s/3s lipo's but is vague on lipo cutoff..
#22
The new low-profile esc looks pretty sweet!
But what are the differences between the programming box that comes with the esc and the LCD box? The LCD box looks quite cool though
Thanks!
Thanks!
#24
i run the venom pro esc and its pretty much the same esc as the speed passion made bye the same company it has the program box and has all the same settings as a speed passion and man i love this thing! no more hauling my 1100.00 lap top to the dusty track just plug my little box in and make my changes. im gonna grab a new speed passion for my up coming kyosho sp and will not even think about buying anything else. speed passion is the bomb. quality stuff im shell shocked its not more popular than it is. looks like they are finaly getting some respect
#25
i ran my exige 2.0 esc with m chassis motor(3300kv) last night in my sc10 and im very amazed on how the truck was with that motor only thing is my motor was getting to around 165 degrees and i know needs to come down or is that a good temp all the time and how high should i worry about temps on theses motors. and does it matter how long i run it it should stay the same ? i have the 75 spur/23 pinion. if i go lower on pinion should cool it off ? thnx in advance Will G
#29
i just went out in my front yard and ran around on and off the throttle dirt and street and ran 16 mins exaclty and only ran 145degree. i ran it pretty hard but i think that did it thnx to all normally you would only run what 6-7 heats and a 10-15 mins main im guessing.
