SmartDiff in Electric >
Old 05-17-2009, 05:53 AM
kufman's Avatar
Default SmartDiff in Electric
Just starting a thread for anyone who is running the Losi SmartDiff in an Electric 1/8th.
I just got mine on Friday and have started messing around with it. One problem I did have was the outdrives are much shorted than the stock RC8 ones, but I can solve this by using AE outdrives. For the meatime I have relocated my center diff back to the stock location and the CVD's are long enough to reach. My initial impression is that this device doesn't do much more than 10,000 wt oil in a regular center diff. My front tires still seem to unload like crazy. I am using the softest springs and only two of them.
Anyone else tried this thing?
kufman is offline
Old 05-17-2009, 06:16 AM
badassrevo's Avatar
Most of the guys in my area are running it in the front, not the center.
badassrevo is offline
Old 05-17-2009, 06:54 AM
UK.hardcore's Avatar
The UK Nitro guys say these diff are good for 30 minutes and then a revision is already needed.
UK.hardcore is offline
Old 05-17-2009, 07:04 AM
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
That's interesting because no one here runs them in the front, only the center.
rearviewmirror is offline
Old 05-17-2009, 11:45 AM
kufman's Avatar
I was only interested in using it in the center to prevent the front tires from ballooning when I get on power. It doesn't seem to do much on that front. What I am really looking for is a spool on power and free diff action off power.
kufman is offline
Old 05-17-2009, 11:50 AM
I'm not even sure about how it will effect the ballooning of the front tires. The guys here who run them on their electric say it aids greatly in lower speed turns. Apparently they can get around the bend much faster w/ the smart diff.
Old 05-17-2009, 12:09 PM
Trader Rating: 19 (100%+)
I use the xray active diff in the front on occassion and it works pretty well. In the front, it basically allows the car to pull more around turns on power, but as soon as you let off the throttle, the diff opens up and you get more turn in. It worked very well when our local track had a big sweeper, you could feel the car pulling hard on power. No one could keep up with me on that turn. However, the off power steering can make the car twitchy in some circumstances.
Edumakated is offline
Old 05-17-2009, 12:14 PM
$Tmoney$'s Avatar
Trader Rating: 28 (97%+)
glue the foams down in the tire to prevent ballooning or run tape around the phone that helps alot
$Tmoney$ is offline
Old 05-17-2009, 12:20 PM
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
I may be wrong but i think if you put softer springs in you will get more on power or accelleration (sp?) out of the corner
Jason Pelletier is offline
Old 05-17-2009, 12:59 PM
bradfox2's Avatar
run two .15s and pack it really really full of grease. I am running it like that and dont seem to have any issues. I think you might have to let it break in too. Mine seemed to balloon at first and then got better with age.
bradfox2 is offline
Old 05-17-2009, 01:18 PM
Shark413's Avatar
Trader Rating: 24 (100%+)
I have been using the SD in my Losi 8ight-T for the past month. At first it didn't seem to being working correctly, tires would balloon under hard acceleration. I then realized I had put the 90 degree ramps in by mistake (less aggressive) and not enough grease (centrifical force had sent most of it to the outside of the diff case). So changed to 120 degree ramps, removed two springs (using only two .15mm springs) and repacked with grease. On the third time out the diff started to work much better, much less ballooning now. I am using it in the center only.
No grease
90 and 120 degree ramps
Shark413 is offline
