Average cost of AMB transponder repair >
Old 05-03-2009, 08:33 PM
Tech Legend
Cain's Avatar
Trader Rating: 268 (100%+)
Default Average cost of AMB transponder repair
I have an amb transponder that stopped working when I went to hook it up on one of my vehicles (it worked immediately prior on another vehicle).
on average, what are you guys seeing for repair costs?
Cain is offline
Old 05-03-2009, 11:25 PM
TheBackmarker's Avatar
They are warrantied for one year, but I've had a dozen or more and some of them for many years and never had to send one in for repair. Generally you just plug it in and turn on the car and you'll see a little green light on it. If the light is working, the transponder is transmitting. If it's not, you probably have a bad plug. Your receiver may also have a bad port. Plug the transponder into another channel for testing purposes. It can be powered from any channel. If the light comes on, get a small y-harness and run it off throttle or steering if necessary. But if it does need repair just call AMB and ask them your questions. Visit their site at http://www.amb-it.com/index.php
TheBackmarker is offline
Old 05-04-2009, 06:57 AM
Tech Legend
Cain's Avatar
I tried this in two different ports in two different receivers (4 ports total) and it didn't work. It worked fine immediately prior to switching it to another vehicle.
I'll give them a call today. Thanks for the heads up.
Cain is offline
Old 05-04-2009, 08:38 AM
I would swap the connector before sending it in. During the swap it may have been enlarged hence not making contact. Was the PT installed in the first receiver for a long time, did it get wet? There may be some oxidation that is not allowing a solid connection. My money is on the connector give it a try.
Thopper is offline
Old 05-04-2009, 09:48 AM
Trader Rating: 49 (95%+)
Hopefully its under warranty, I called AMB about replacing a sheared off lead on mine and they said they do not repair the RC personals, only replace them and offered me one for $95.
loopedout is offline
Old 05-04-2009, 10:22 AM
Tech Legend
Cain's Avatar
this won't be a warranty unit.
Cain is offline
Old 05-04-2009, 11:08 AM
exploder's Avatar
Trader Rating: 29 (100%+)
cut off the old connector and soder on a new plug ive done this a few times ive even taken the case apart and sodered a new plug onto the circuit board
exploder is offline
Old 05-04-2009, 11:12 AM
Mine is sheared off at the case, how are you opening the case on them, are they potted into the case?
Old 05-04-2009, 11:29 AM
exploder's Avatar
i cut the end off of it with a sharp blade and they r shoe good in there and u have to be careful cutting the shoe goo away
exploder is offline
Old 05-04-2009, 11:30 AM
exploder's Avatar
or the easy way is cut the bottom out and pull it out that way and then just heat shrink it all back together when your done like heat shrink the whole case. make sure to write down your number first
exploder is offline
Old 05-04-2009, 12:29 PM
thanks, ill give it a shot, that shoe goo stuff is potting or conformal coating
Old 06-09-2009, 03:53 PM
exploder's Avatar
ill fix transponders for 30 bucks. pm me if u r interested. ill solder on a new wire onto the board. let me kno. pm me and ill give u my address
exploder is offline
Old 09-26-2009, 11:54 PM
bigfix's Avatar
Exclamation AMBrc DP wire replacement
I fix these professionally for $35AUD (about $29USD)
Good as new.
I also fit new batteries in most AMB rechargeable handout transponders.
www.transponderservices.com
regards
Jeff
bigfix is offline
Old 09-27-2009, 01:35 PM
Trader Rating: 19 (100%+)
Cain I suggest you send it to TeamMRT.com rclaps.com is their website. You send them in your broken amb they will clone it on to 1 of their much smaller units. You get to choose the length of the wire the color of your led wether you want tabs or not. They are just awesome. I just got 1 of their newest ones also the wires are replaceable 4 tiny screws and thats it. Also by sending your ol Amb in they give you a discount. With out a discount I just paid like $62 shipped to my door, and they are 1/2 the size of the amb's, use like a 3rd of the juice just all around a better product to me. Check them out. I wont ever spend $109 again.
malik is offline
