Old 12-13-2003, 12:03 PM   #1
Nrctc3's Avatar
Send a message via AIM to Nrctc3 Send a message via Yahoo to Nrctc3
Default need info for dirt oval
I'm looking to modify my NTC3 into a dirt oval car. What do I need to do? Do I keep the 2 speed? I need info for it, I know nothing about dirt oval.
Nrctc3 is offline   Reply With Quote
Old 12-13-2003, 03:34 PM   #2
I would take out the droop screws so you can get maxium rideheight, put a single speed in, and get diffrent tires.
AE Racer is offline   Reply With Quote
Old 12-13-2003, 03:36 PM   #3
Nrctc3's Avatar
I got a set of tires & a late model body for it... But why take the 2 speed out? The straights are 250ft.
Old 12-13-2003, 03:40 PM   #4
Is it a bluegroove type surface? Id leave it in then, but if it's dusty and there's some loose dirt it will probably end up failing.
Old 12-13-2003, 03:42 PM   #5
Nrctc3's Avatar
it's pretty smooth, smooth enough to use HPI's Pirelli tires on.
Old 12-13-2003, 11:50 PM   #6
Send a message via AIM to Gped0124 Send a message via Yahoo to Gped0124
Get a EDM type body, they should sell them at your hobbyshop. Use Proline Road Hawgs, or your track should let you use some foamys. set for maxium ride height and use softer oil and softer springs. Then, move all the weight possible to the left side, even use some lead weights if you have to. Ditch the two speed, it will only cause problems. Then, get a BMS Sprint car
Gped0124 is offline   Reply With Quote
New Dirt Oval Track - Cincinnati Dirt Bowl CCR Oval, Larger Scales and More 10 05-04-2009 08:49 PM
PAVED-DIRT OVAL-DIRT ROAD COURSE-GEORGIA PRIME TIME Track Locator Forum 0 09-11-2008 12:27 PM
Info on oval pan cars? Storey Oval, Larger Scales and More 7 09-03-2008 01:59 PM
Looking for a xxx-t set up for dirt oval TeamFast R/C Items: Wanted to Buy 1 05-11-2008 10:47 AM
WTT a 12th scale oval tricked out for custom dirt oval car BIGDON18 R/C Items: For Sale/Trade 3 06-21-2005 11:19 AM
