toe in stadium
toe in stadium
hi can some one help me with toe in settings for and 2 wheel drive staidium truck and camber please
This is for an associated T4
I'm presently also trying to sort out my E-Firestorm setup. There is a thread for the truck elsewhere but since I'm looking at steering issues, it's relevant here I guess.
My truck has been suffering from understeer for a while now, and after increasing the steering EPA, it turn a bit better. Right now, the truck only respond well 2/3 way into the turn (throttle off). Initial turn-in wasn't great, and it went wide mid-way. Only seem to grip at the last part of the turn.
So I heard that adding camber in the front wheels helps steering, and having some bit of toe-out helps steering-in. Any suggestions, anyone?
And may I know how do I go about getting the optimum toe angle and camber degree, how do I gauge and what to look out for?
Also, having toe-in on the rear wheels aids straight line and corner exit stability. Tried that and it worked, but does too much rear wheel toe-in limit steering?
(Sorry for thread hi-jack and the multiple questions.
Thanks for the reply, so now I know it's actually a chassis limitation. Had driven some pal's XXX-T and T4 before and they turned much better, so it has since become a project to set the HPI to close in on them.
Another bit,
is it normal for 2WD trucks to wear more threads off the inner rear tire, or did I set my camber a little off?
I'm figuring the wear could be during turns, where centrifugal force help the outside wheel grab traction, but the inside wheel spins off the differential. And all that half-traction spinning is when the inner thread wears.
Another bit,
