!SETUPS! Team Associated SC10 !SETUPS!
Hey,
I've got myself an SC10, built it, and have put a VXL system in it, I have no idea what gearing or motors, ESC's, servo's, camber, toe in and etc. I should use.
So list what you've pimped your truck with!
ESC: Traxxas VXL 3s
Motor: VXL 3s 10T
Servo: Traxxas 2075
Receiver + Transmitter: Traxxas Micro and Traxxas 2ch TQ
(^Basically TRX Slash setup minus motor+ESC^)
Camber: ??? (List yours so I know what to do)
Toe In: ??? (List yours)
Gearing: 23/87 (Only spare, List yours so I know what I should do)
~Lawso
ESC: Traxxas VXL 3s
Motor: VXL 3s 10T
Servo: Traxxas 2075
~Lawso
CC Mamba Max / 5700 motor
Front: Gold springs, 35 wt oil, #3 piston
Rear: Green springs, 30 wt. oil, #2 piston
Spektrum DX3r and sr3100 receiver
Hitec HS-7965MG servo
3 ozs. weight, 1 front bumper, 1 front battery tray, 1 rear battery tray
Wheels / tires: Set 1 (stock tires and foams) Set 2 (pro-line switch/slayer with AKA medium foams)
1.5 degree camber front and rear
30 degree caster blocks and 1 degree toe in fronts
Rear camber link moved to outer hole on hub carrier
Track time this weekend to see what to do next.
