Old 04-12-2009, 02:16 PM   #16
glassdoctor's Avatar
Originally Posted by SuperEk4 View Post
Like ur hardware 9/10
Remember to monitor the esc n motor temp, I burnt 2 feigao n 2 esc becoz I never bother. Now I hv a telementary system in d car n a batt indicator on d shell so when batt low car can come back to change batt ESP in a 30min main.
Dun mind I borrow this thread to rate my setup too
CRT x1 rc monster converted
Motor medusa 1600kv
Batt 6s 5000 zippy
Hobbywing 100amp plane esc with fan attached n water proof
Slipper center diff 46t spur(for the jumps n hard brakes although I dun brake much)
11t Pinion
Wat u guys think?
I ran 2 race (all 10mins heats) ( bash 25mins staight to test d batts) no main yet due to rain, temp was 40-50 degrees just abit too much torque. The slipper diff is new not tested yet.
If it's the 70mm or 80mm motor, and the esc is running without cogging... then I think it's a fine setup. You have run it, so you should know if it's a good setup
7/10 with a bonus point for originality = 8/10
glassdoctor is offline   Reply With Quote
Old 04-12-2009, 11:54 PM   #17
SuperEk4's Avatar
Trader Rating: 32 (100%+)
thx alot glass doctor, it's on a 70mm medusa n no cloggin. Just the brakes abit hard, hopefully the slipper diff can help to soften it
Hobbywing-Acorn Racing-ManiaRC-UpgradeRC-Hong nor-Rc monster-Blackbeard-Rc-MoosDesign-SweepRacing-Boca bearings-Tresrey USA-Velociti raceware-Tekno Rc-Team J-JPL Models-SNR Graphite (RETIRED)
SuperEk4 is offline   Reply With Quote
