Old 04-11-2009, 03:16 PM   #1
Default sensored or sensorless
What is the difference between a sensored and sensorless motor? Which is more popular and why?
cassidy is offline   Reply With Quote
Old 04-11-2009, 03:20 PM   #2
beginner4life's Avatar
Trader Rating: 9 (91%+)
Sensored knows where the rotor is at all times, but on the flip side, usually can't handle as many volts. Sensorless is probably more popular.
*Team Terribles*
RC8T-RB S3-Hitec Servos- Spektrum
beginner4life is offline   Reply With Quote
Old 04-11-2009, 03:33 PM   #3
shanty140's Avatar
The sensored motor eliminate almost all cogging because like was said it knows wheres the motor is at all times. Where as sensorless only approximately knows where the motor is and because of this can cause cogging. Where you mostly see the problem is if you spin out and roll backwards. The motor might clog when you give it throttle again. The sensored motors usually use more power and like what was said usually only handle up to 4S. Tekin new ESC uses both sensored and sensorless to get the best of both worlds. It uses sensored on the start, then switches over to sensorless once its moving. I am using the MMM and I havent had any cogging issues at the moment, and alot of people I know are running it also and are not having any issues as well.
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, Sav÷x SC-1251MG Servo
shanty140 is offline   Reply With Quote
Old 04-11-2009, 03:56 PM   #4
Gliptal's Avatar
For racing sensored is by far the most popular as it eliminates any chance of cogging.
Sensorless systems are generally cheaper and popular for bashing, they can be used for racing as well in mod class.
Gliptal is offline   Reply With Quote
Old 04-11-2009, 04:45 PM   #5
Originally Posted by shanty140 View Post
The sensored motor eliminate almost all clogging because like was said it knows wheres the motor is at all times. Where as sensorless only approximately knows where the motor is and because of this can cause clogging. Where you mostly see the problem is if you spin out and roll backwards. The motor might clog when you give it throttle again. The sensored motors usually use more power and like what was said usually only handle up to 4S. Tekin new ESC uses both sensored and sensorless to get the best of both worlds. It uses sensored on the start, then switches over to sensorless once its moving. I am using the MMM and I havent had any clogging issues at the moment, and alot of people I know are running it also and are not having any issues as well.
What does clogging mean?
Old 04-11-2009, 04:56 PM   #6
shanty140's Avatar
Cogging is when you go to give the car throttle. And the vehicle hesitates to accelerate. I guess you can kinda describe it as a Low Speed lean on a nitro vehicle. It is a bit different though.
Race Vehicles:
Old 04-11-2009, 05:22 PM   #7
Gliptal's Avatar
Actually it is cogging, not clogging.
Old 04-11-2009, 08:44 PM   #8
shanty140's Avatar
LOL my bad
Race Vehicles:
Old 04-11-2009, 08:54 PM   #9
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
It kind of stutters a bit until it starts picking up more speed.
Sensorless is not so bad. It could be my imagination, but once I updated the firmware on my Sidewinder ESC, everything was a lot smoother.
Dan is offline   Reply With Quote
Old 04-11-2009, 11:42 PM   #10
I like sensorless for the cost factor if nothing else. I get a little cogging with my 3300kV motor on the Sidewinder, but nothing to worry about. I know it will be an issue when I use it against Tebo in the A-Main, but until then i'll just muddle my way through.
I have a Tekin 537 coming with an R1 I got filthy cheap from Tower of all places! Be interested to see how that goes with cogging. They are supposed to be a lot better as they have low turns for the kV. Fingers crossed!
JR007 is offline   Reply With Quote
Old 04-12-2009, 08:18 AM   #11
gweed's Avatar
sensored is the only way to be. its so smoove. plus if you want to run at a roar sponsered event only sensored motors are legal
kyoslo RB5/ novak motors/ LRP sphere/ m11/ orion 4800,3800,3600/ blazin chronic racing/wphukuall radio/ raikkonen body/ mongoosed km-mini inferno with the multiplex red ass servo that owns johnny b-main and drew/ now at lir the JDM zx-5 sp mugen edition
"team bad guys"
gweed is offline   Reply With Quote
Old 04-12-2009, 08:29 AM   #12
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Sensorless is ROAR approved for Mod if you check they approval list you will find Castle Creations motors listed.
If you want to run the 17.5 stock class then a Sensored type setup is better.
ST Racing Concepts (STRC)
Old 04-12-2009, 08:39 AM   #13
Go with sensored if you are racing or are on a slippery surface. Go with sensorless if your just bashing and want crazy speed. (Slash + MM 7700= )
Joseph D. Jones (DAD) - Best Racing buddy and father ever! Gone but not Forgotten
Team GB Old Skool
xrayzone is offline   Reply With Quote
Old 04-13-2009, 10:14 AM   #14
Rick Hohwart's Avatar
Sensored motors not only elimate cogging, they typically provide better throttle control. If you are racing, you will benefit greatly from a sensored system.
Rick Hohwart is offline   Reply With Quote
Old 04-13-2009, 04:01 PM   #15
JeromeK99's Avatar
The majority of folks at our local track are brushless.. and run just about everything out there. The only folks that have cogging problems with sensorless setups are those with cheap sport packs and old worn out race packs.
For the same price as a sensorless, you can get budget minded sensored systems like the Novak Havoc with down to an 8.5 motor for under $150.
Given the choice, I'd go sensored!
Jerome
JeromeK99 is offline   Reply With Quote
Tamiya mini cooper sipaboy Electric On-Road 29687 12-10-2017 04:07 AM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Traxxas VXL! Where'd ya go bowl806 Electric Off-Road 58 07-09-2009 01:29 PM
Ques for Sensored motor guys?? boomerrw Electric Off-Road 11 03-18-2009 10:26 AM
What has Roar done for me lately ? Jason Pelletier Electric Off-Road 212 09-06-2008 04:25 PM
