Old 04-09-2009, 07:08 PM   #16
jd267's Avatar
Trader Rating: 36 (100%+)
Originally Posted by 801Funk801 View Post
i see i see... the best setup I have found is a MM ESC and the vxl motor. I think you would be happy with this setup due to the ability to tune the esc and the fact that the VXL is a 3500KV motor that runs super strong. better yet if you dont care about tuning the esc and you just wanna bash run the full VXL system its strong and stays pretty low temp wise.
mamba and vxl.... gear the shit out of it...lol my friends flys its faster than my 5700 on the track and the street because he has so much more torque..
jd267 is offline   Reply With Quote
Old 04-09-2009, 07:12 PM   #17
801Funk801's Avatar
Trader Rating: 16 (100%+)
I think if you run the MM/VXL setup and run similar gears to your friends set up you guys will be right there with each other.
801Funk801 is offline   Reply With Quote
Old 04-09-2009, 07:25 PM   #18
arcarle's Avatar
no i trust you on the temps but the sidewinder is no where near the mamba max esc amp output wise [what i have]
The only time the esc's amp output comes in to play is if you are using a battery that can put out more amps as well. Your battery is only putting out around 125 amps continuous. Im sorry but the sidewinder 4600 and 5700 can handle that amperage and so can the MM. Your trouble has to be something else. Again I am not trying to frustrate you at all only trying to help.
arcarle is offline   Reply With Quote
Old 04-09-2009, 07:44 PM   #19
jd267's Avatar
i here you....like i said the probblem is the motor.. look around everyone says the same thing about the 5700 in the slash... i have no need to bicker about it i no from owning it and trying gearing....
Old 04-10-2009, 02:09 PM   #20
arcarle's Avatar
I was thinking about getting a 5700 too when i got my 4600. Glad I didnt now
301 Raceway in Maryland Sandra Racing Forum 13734 04-13-2017 11:24 AM
Low compression in my engine Mugen MBX-5 Offroad Nitro Engine Forum 20 12-25-2016 01:24 AM
1/10 Formula 1 Car Forums kuanseng1981 Singapore R/C Racers 4449 07-25-2015 12:28 AM
2009 Hobbytown USA St. Charles Racing thunderbt3 Wisconsin & Illinois Racing 934 04-16-2010 10:05 AM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
Need Prayers? Come here! IH8Racing R/C Racers 4 Christ 16 07-15-2009 09:00 AM
MBX5 kyracer Nitro Off-Road 1461 01-10-2008 10:43 AM
