Install a 1/8 wing on B4?
hey guys
has anyone run a 1/8th wing on the B4? The wings seem much stronger and will provide more consistence down force since they don't bend.
The only thing is finding a wing that isn't too large.
I did for my XXX-CR, it weighs 1.5oz but I use this since I use light batteries
it gives mroe rear grip and I just added 3oz on my front nose. I use LiFe not Lipo.........I like the wing
These are some older pictures I took, I have better decals on wing now and wndo tint on car body
Thundertiger ST-1 wings
You should check out the OFNA CRT .5 wing,
It looks much more scale than an 1/8th wing and is much lighter.
The Acadamy 1/10th Svb2 4wd buggy also has a plastic wing.
http://www.amainhobbies.com/product_...ducts_id/19317
The .5 wing will fit better than an 8th wing. You will break your wing mounts more often with the stiffer wing.
Also with the heavier wing the buggy will nose up in the air more easily when you jump.
batteries are so much lighter than lipo's that it would do backflips without it during a jump. The wing in my picture is by far the best wing for your B4 It is very similar in size to your B4 wing and is the same size as the XXX-CR wing.
Exactly my point for only using with light batteries. The future has already made NiMH batteries obsolete.
Get a 7" Jconcepts wing, you will find the downforce you want without the 8th scale wing.
Notice velcro strap for my unique batteries that are light weight.
My XXX-CR turns better than a B4 as well mine has many mods
Thats why i have a lipo setup on my car and I don't need weight and the car still turns just fine.
I don't use drag brakes, that would simulate weight as well Lipo's are dangerous and don't last near as long, yes, but I added weight on mine to not flip backwards in the air, I refuse to use drag brakes unless 1/8scale. I had to get my car back to the CG of the stock kit you see. it was either 7oz in the battery tray or 3oz on the nose, was a no brainer, It grips like a 4wd no lie
The CRT.5 wing is really tough, but quite a bit smaller than a 1/10 2wd wing. I'd go with a Hot Bodies Lightning 10 wing. It's sized btwn the crt.5 and 1/8 wings.
The wings that are supplied with the stock/OEM bodies are made from thin polycarb. They do tear easily.
JConcept makes much stronger (thicker) polycarb. that last a LOT longer.
The CRT .5 and other hard plastic wings put too much weight too high on the car. They also don't flex enough during a crash and there is more energy transfered to the wing mounts than they were ever designinged to handle.
