Old 04-06-2009, 09:20 PM   #1
RallyImp05's Avatar
Default slash noise
so i was running my slash today and all the sudden i start hearing a wierd clicking noise coming from the rear end. i only happens when the motor turns the wheels, and it gets faster the faster the wheels spin. i disconnected the motor from the tranny and the noise stopped, so i figured maybe something got into the tranny, but nothing. also pulled the diff apart and didnt see anything there either. the sound doesnt seem to be coming from the wheel bearings. any ideas? its a stock slash.
Traxxas Slash VXL
RallyImp05 is offline   Reply With Quote
Old 04-06-2009, 09:25 PM   #2
$Tmoney$'s Avatar
Trader Rating: 28 (97%+)
something broke in motor?
$Tmoney$ is offline   Reply With Quote
Old 04-06-2009, 09:27 PM   #3
RallyImp05's Avatar
motor sounded fine when i disconnected it from the tranny.
Traxxas Slash VXL
Old 04-06-2009, 09:35 PM   #4
dis connnect one drive shaft at a time see if it goes away could be a mesh problem between ring an pinion
73ltcamaro is offline   Reply With Quote
Old 04-06-2009, 09:37 PM   #5
Trader Rating: 15 (100%+)
same history as mine...
omar_pr is offline   Reply With Quote
Old 04-06-2009, 09:39 PM   #6
Could be that one of the shock screws backed out and is rubbing on the axle? This happened to my son's slash. It wasn't a consistent noise but it was pretty loud... just my 2c
Jeeper is offline   Reply With Quote
Old 04-06-2009, 09:40 PM   #7
RallyImp05's Avatar
ever find out what it was? and did it have any adverse affect?
Traxxas Slash VXL
Old 04-06-2009, 10:06 PM   #8
RallyImp05's Avatar
you know that is a good idea.. i noticed some wierd etching on the axles but didnt think anything of it. i will have to check that once i get it all put back together.
Traxxas Slash VXL
Old 04-06-2009, 10:21 PM   #9
that was happening to mine and there was something in the drive shaft so i got some perfect duster and cleaned everything out and the noise stopped
Hpi vorza
e-revo bl
slash 4x4
salabarria is offline   Reply With Quote
Old 04-06-2009, 10:27 PM   #10
RallyImp05's Avatar
on my list of things to try.
Traxxas Slash VXL
Old 04-06-2009, 11:03 PM   #11
Suspended
try dynamite??
Lightin' is offline   Reply With Quote
Old 04-07-2009, 12:01 AM   #12
offtraxx's Avatar
Trader Rating: 59 (100%+)
check ur spur. I have had just one tooth break before. it will still work but does clik
I'm not a RC addict. addict's are in denial, I admit I have a problem
offtraxx is offline   Reply With Quote
Old 04-07-2009, 04:13 AM   #13
arcarle's Avatar
I had the same thing happen 3 different times. The clicking will come and then as soon as I start trying to figure out what it is it stops. Ony to return again later. Weird.
arcarle is offline   Reply With Quote
Old 04-07-2009, 11:33 AM   #14
snowboard094's Avatar
i had this problem to. In about a week of running my slash with this noise the motor went out on me. I went BL and never heard it again.
-Electrical wiz-Let me check your shorts.....that came out wrong
"Team Terrible"
Ofna Hyper 10sc
T-maxx O.S .18tm
snowboard094 is offline   Reply With Quote
Old 04-07-2009, 01:06 PM   #15
MojoManDan's Avatar
I too had the same problem toward the end of running just my first battery pack. When I rotated each tire in the same direction, I noticed that they got "tight" at one spot during each full rotation. I removed the spur gear cover and I checked my pinion and spur very carefully, but they were fine with no missing teeth. Apparently, the mesh was misaligned at the same spot during each rotation. There was no dirt or stone causing the problem.
Just to be sure my motor was ok, I too removed it, hooked up a battery pack, and ran it in both directions with no abnormality.
Then, I removed the spur and disassebled the slipper, but found no problems with the slipper. You wonder where I am going here, right?
Well, I found that while tightening the slipper nut against the spur gear, I had to make absolutely sure that the spur gear was on straight. Otherwise, I'd induce a very slight wobble while the spur was turning. This then screwed up my gear mesh, and caused a "click" when the mesh got too tight.
I have no idea why this should occur, unless some slop exists with the fitting of the spur gear. Since then, I only ran the Slash for 30 seconds to test it, but everything was fine. I will report back after another full pack...
MojoManDan is offline   Reply With Quote
Outdoor FREE Slash track in Seattle t0adman Northwest Racers 4229 09-07-2016 02:41 PM
Traxxas Slash, SETUPS ONLY ! ! ! ! ! nobike Electric Off-Road 769 09-13-2014 03:35 PM
MY slash is going in the trash Leroy1234p Electric Off-Road 53 07-10-2009 09:22 PM
I got a huge problem with my slash Leroy1234p Electric Off-Road 30 05-06-2009 06:04 PM
