Old 12-03-2003, 04:43 PM   #1
Send a message via AIM to CrashDummy0412
Default Need more compression!
Alright, I just purchased a GS Storm RTR (my first ever nitro car) and it is not starting the way it should. Everything else is working fine: the main needle is 3 turns out, the air filter is oiled, the glow starter ignites the glow plug, the carburetor is primed and the pull start is alright. However, I can easily turn the flywheel with my thumb, obviously meaning I am lacking compression. What are some options I can do to my buggy to increase the compression?
CrashDummy0412 is offline   Reply With Quote
Old 12-03-2003, 06:15 PM   #2
KINGZJ's Avatar
Send a message via AIM to KINGZJ
You can send your piston and sleeve out to be resized. If you are interested in this email me at [email protected]
KINGZJ is offline   Reply With Quote
Old 12-03-2003, 07:19 PM   #3
when you turn the fly wheel are you sure the piston is turning because it is possible that your fly wheel is loose and that would throw off the timing of the engine and make it very difficult to start.
igkyoa is offline   Reply With Quote
Old 12-04-2003, 06:58 PM   #4
r1harper's Avatar
Trader Rating: 24 (100%+)
i had the same prob, the flywheel was slipping on the collet. nitro will raddle some stuff loose. invest in locktite.
r1harper is offline   Reply With Quote
Old 12-04-2003, 09:23 PM   #5
Smoke21's Avatar
Location: Pacifica, California OR Clearlake Oaks, California
Send a message via AIM to Smoke21
yeah check the flywheel if your car is that new it shouldn't be that worn already...
Smoke21 is offline   Reply With Quote
Old 12-07-2003, 12:03 AM   #6
MMR_Slingr's Avatar
Send a message via Yahoo to MMR_Slingr
pull a couple shims out from under the cylinder head to reduce combustion chanber at TDC(top Dead Center) which gives u more compression on air/fuel mixture
MMR_Slingr is offline   Reply With Quote
Old 12-07-2003, 12:17 AM   #7
KINGZJ's Avatar
MMR,
While you can do that it should only be done if you understand completely what you are doing. You need to maintain a predetermind gap at all times. A good guide line is .006 per 10% of nitro content. I set my .21's at about .020 I prefer to be a little over the line in case of any measuring error. O I forgot to mention I do run 30%
Bad Compression Maybe? duratraxrc Nitro Off-Road 3 08-27-2008 06:25 PM
Low Compression??? I can fix it. bigde2001 Georgia Racing 12 03-02-2008 08:38 PM
compression 32819toon Onroad Nitro Engine Zone 2 05-05-2006 10:35 AM
Low Compression Or Not? Evan Nitro On-Road 1 10-26-2004 08:36 PM
compression alucard13 Nitro On-Road 6 04-10-2003 07:08 AM
