SC10 Thread
Old 10-12-2011 | 03:06 AM
  #7456
idrummerboy13's Avatar
Originally Posted by rustybaker
Thanks for sharing your experience. I ordered the whole AE diff rebuild kit, 3k oil, 5k oil, black grease, and silcon. What do you guys recommend to solve this? Do as NV Racer did and pack it full of grease and touch nothing else or rebuild it using the rebuild kit and 5k?
Also, I can't seem to find the answer to the shim fix. The rebuild comes with #9829 shims. Should I add these to the shims already there (double up on both sides) or just replace the ones there with the 9829s?
try 50 weight shock oil. i used in b4.1 rtr and it was very very good..
idrummerboy13 is offline
Old 10-12-2011 | 05:47 PM
  #7457
mxracer458's Avatar
Anyone try the off set hex wheels yet?thinking about try a set and was curious if it handles any different
mxracer458 is offline
Old 10-12-2011 | 06:06 PM
  #7458
I've been running the AE hex parts for a couple of weeks and to be honest I haven't noticed much difference in handling, but I'm a novice level driver at best, so I may not even notice any differences.
L8Braker is offline
Old 10-12-2011 | 06:17 PM
  #7459
mxracer458's Avatar
I meant the 3mm offset hex wheels
Old 10-12-2011 | 07:50 PM
  #7460
Default Affordable Motor Suggestions
Running a stock sc10 rtr with a 3300 Reedy motor. Looking for a little more power to make our track's triple. Want to use with the stock esc. Most folks are running the Castle 3800 combo but I want to keep the cost down. Any suggestions on an affordable motor that is also reliable? Thanks
Murray100 is offline
Old 10-12-2011 | 08:54 PM
  #7461
jirish617's Avatar
hey guys...looks like im getting bit by the rc bug and the short course bug. I am in the hunt for a factory team sc10. I am going to be running on an indoor clay offroad track. Looking to see if i could find a setup sheet and just some overall tips. Ill likely be running the stock class because it seems to biggest at the local track. I used to race when I was extremely young, and my father was the mechanic, so essentially im a rookie and don't know a whole lot.
jirish617 is offline
Old 10-12-2011 | 09:35 PM
  #7462
Default great posts
What a great thread. Subscribed.
chaduro is offline
Old 10-12-2011 | 09:58 PM
  #7463
CraigMBA's Avatar
1, Find out what tires the local fast guys run. Patterns and compounds.
2. Look for setup sheets that use those tires in the internet.
3. ?????
4. Profit
I read an article 20 years ago, and that's effectively what Cliff Lett suggested save step 2. If it works on those tires it'll work on your track.
Good luck, this has been a fabulous strategy for me. I always unload fast, and always finish in the top 2.
CraigMBA is offline
Old 10-12-2011 | 09:59 PM
  #7464
CraigMBA's Avatar
I added 2mm to the front (each side) and 3mm to the rear. It's super stable compared to before, slides better, and traction rolls less.
Did I mention it was faster too?
CraigMBA is offline
Old 10-12-2011 | 10:07 PM
  #7465
The Joker's Avatar
Questions??
What "offset wheels" are u talking about???
The Joker is offline
Old 10-13-2011 | 06:10 AM
  #7466
mxracer458's Avatar
Losi scte off set,little wider then the 0 offset
Old 10-13-2011 | 06:28 AM
  #7467
Asharus's Avatar
What about the new JC Hazards?
Asharus is offline
Old 10-13-2011 | 06:48 AM
  #7468
ShortCourseOnly's Avatar
I ordered a bunch of the JC Hazard wheels for my SC10 and SC10 4x4. With 3mm more width per side this will match the Kyosho which looks very stable on the track.
ShortCourseOnly is offline
Old 10-13-2011 | 06:57 AM
  #7469
Asharus's Avatar
Can you provide some feedback after you run them? I want to switch from the Rulux wheels, but I have a ton of tires and will find it difficult to switch. I'm also still running the standard hubs up front. As far as I know, the Hazards only come as 12mm hexes.
Asharus is offline
Old 10-13-2011 | 10:14 AM
  #7470
What is the offset on the proline protrac renegade rims with 12mm hex?
maxpowers is offline
