SC10 Thread
#616
i started to the rear ones and then the instructions call for total of 2.8"...
but the one i'm holding is longer.... oh well, i just eyeballed and seems to look okay with driveshaft being level to the ground.
btw, what the easy way of popping the cups off the ball joints without tearing/wearing them down from constantly popping on and off...
#618
the tie rods that were in the bag for that step were the wrong ones... right?
#620
the directions say to use grease on the o rings , i think thats wrong . i have always used assosiate green slime on the o rings and never had a problem with leaky shocks.... well unless i bent the shafts .
#621
well after one practice and one race night my box stock sc10 has worked fine. i did switch out the kit tires for traxxas slash tires. i tried the kit tires and have tried the pro-line tires before, but the only ones that seem to work at my local track are the slash tires. i think we should stick with a tire that won't wear out, but i also agree that we might need a tire with more traction. i don't want to have to buy new tires every other week to keep up though. that's what i've liked about the slash tires. they work better after there a month or so old and never seem to wear out.
#622
i almost forgot, here's the short list of what will fit the stock wheels as of now.
feel free to add to these if i missed anything.
i've heard, but not seen that jconcepts makes a goosebump tire ???
pro-line slayer tires (NOT PRO-LINE TIRES FOR A SLASH)
traxxas slash/slayer tires
and of course the stock tires that come in the kit.
i do hope that everyone sticks with the stock corr type wheels and doesn't allow t4 or 1/8th scale wheels to be allowed in this class.
#626
Well fri. night the SC10 made its first run on an outdoor loamy but good traction track. There were two of us and we were 1st and 2nd an a lap ahead of third with a Slash. We both ran the J Concepts Goosebumps with black grease in the diffs and they were on rails. I also TQed stock truck and the times of the SC10 were pretty close to my T4 laps. I'm going to make a few adjustments but if you have any doubts about the black grease in the diff I'm telling you to try it first. I actually think its as fast as the T4 except it was traction rolling in a big sweeper so I had to feather it through that section. Everyone was impressed but a few of the Slash guys and we told them going into the race that we didn't count against them because it wasn't fair. I haven't grinned like that racing in a long time!
#628
problem solved...
2 full turns. now it's loosesy-goosy...
thanks...
NEW issue... what is the deal with the roll pins for the rear axles???????
on the firearms i work on, i use a punch and a small hammer to drive them through...
any secrets?
can i switch out to a hex hub???????
thanks...
any secrets?
#629
im looking to pick one of these up since im tired of nitro(hours of cleaning,cost ect)Its been a long time since i ran nitro and things have changed.Im looking to get back into racing,so i need to know whats a good brushless/lipo combo to run?i used to driving fast with 8th scale so im looking for something quick but yet drivable.any help would be appericated.It looks like electric is making a comback in so cal
