SC10 Thread
#2806
Correct me if I'm wrong, but the newer kits came with more then one shim per side in the differential assembly?
What are your guys advice on converting to a hex adapter in the rear? What parts do I need and what rims will fit the rear (as well as the front to match the new style of rims)?
#2807
#2808
Tom Chang, you're correct. The newer RTR trucks (not sure about the kits?) come with a "diff repair kit" that has 2 additional shims. The original ones were too thin, so you just add the second set of shims.
#2810
To date the best original wheel I have is one that spun all the meat out of it and I filled the entire area with JB. When it started to kick I cut one pin slot out.
#2811
I have found that the fix for the ols style wheel is to take a plastics tree that is the same thinckness as the hole and cut to fir in the wheel holes, I happened to find the perfect diameter that fit snug enough...
#2812
I got tierd of stripping the rear rims...& bought the relux rims from Jconcepets for the Slash..put on some Hexxes..all done. I still run the Relux rims in the front for the SC10 just to keep a good all around look
#2815
So is there any benefit to a gear diff over a ball diff. A ball diff you can adjust the tightness of the diff. The gear in the sc10 has no way to tighten or loosen. So the ball diff is much better. Does that sound right.
#2817
Curious.... is it possible to post a pic of how it looks like?
My kit came with only 2 shims for the inside of the diff case. I read somewhere that the "new" kits are supposed to come with thicker shims.... not sure on that, mine looked thin...
so I added extra shims anyway, I guess that would take out some slop between the gears. The diff works fine, no binding, so I just gotta test it on the track this week end.
#2818
I have one of the original kits and have yet to strip a wheel but I've also owned AE kits for years and what most people do is overtighten the wheel nuts. Just bottom out the nut. If you overtighten the nut it will strip the nylon and it won't stay tight. If the nut screws on easy then replace it. After every heat I check the nuts just to make sure they haven't backed off. You can also buy these nuts at any good hardware store much cheaper than the stock AEs. Keep extra in your tool box.
#2819
What is everyone running for grease in there diff
