SC10 Thread
Old 08-25-2009 | 09:11 AM
  #2446
gashuffer's Avatar
Originally Posted by Phazewun
Here ya go !! the pictures i promised
SMC 5000 hardcase lipo
Why don't you hard wire the esc wire to the battery direct with banana plugs instead of having that deans connector. This way you have a direct connection? you can still use that deans to charge your battery??
gashuffer is offline
Old 08-25-2009 | 09:18 AM
  #2447
OG RC 10T's Avatar
Banana plugs are not hard wired, There plugs. Wouldnt that be a connector just as the deans is.
OG RC 10T is offline
Old 08-25-2009 | 09:22 AM
  #2448
will g's Avatar
Originally Posted by CBHVR6
i haven't run it yet but i had to put a 23t pinion on because i can't get the motor to move enought to get any smaller pinions to meet the spur. theres a problem
if you look in my pics above in the page before i have the milled motor plate but the motor is turned where the wires are facing more forward and that 14 fits fine
will g is offline
Old 08-25-2009 | 09:23 AM
  #2449
gashuffer's Avatar
Sorry. yes they are a connecter per se but if you eliminate the two deans and plug in direct you will have a much better more efficient connection. Just an option to think about.
Old 08-25-2009 | 09:27 AM
  #2450
gashuffer's Avatar
Actually my bad. I thought that battery has female inserts. Thats how I run my Team Orion packs. Sorry about that
Old 08-25-2009 | 09:41 AM
  #2451
Phazewun's Avatar
Hehe yea believe i dont like all these connectors everywhere but SMC is the loose
My 2 orion 3800's i can hardwire straight for onroad, but this is pretty much the only way i can do it for SMC batterys.
Phazewun is offline
Old 08-25-2009 | 09:42 AM
  #2452
CBHVR6's Avatar
so if i can get the motor turned to face the wires front, i can run a lower tooth pinion like i want to?
CBHVR6 is offline
Old 08-25-2009 | 09:43 AM
  #2453
Phazewun's Avatar
If you start to run that low of a pinion you would be better off changing your spur and pinion i think, not 100% sure tho cause im a retard when it comes to gearing
Phazewun is offline
Old 08-25-2009 | 10:03 AM
  #2454
will g's Avatar
you can do that if you get the final drive ratio the same or darn close
will g is offline
Old 08-25-2009 | 10:06 AM
  #2455
Phazewun's Avatar
So 16.87 would be the same as X / 75 ?
Phazewun is offline
Old 08-25-2009 | 10:09 AM
  #2456
whipnet's Avatar
Forum had me on wrong page
Comment deleted
whipnet is offline
Old 08-25-2009 | 11:10 AM
  #2457
will g's Avatar
im not sure what would be equal to that but i would think someone else should be able to help tell you where to start on 75 ... final drive ratio is not coming up close.
also can go the sc10 gearing on rc tech here in the electric off road alot of people posting gearing stuff
will g is offline
Old 08-25-2009 | 11:22 AM
  #2458
gashuffer's Avatar
Here is some data to help you along.
http://aedownloads.com/pdf/gear_ratios.pdf
Old 08-25-2009 | 11:24 AM
  #2459
OG RC 10T's Avatar
Old 08-25-2009 | 08:35 PM
  #2460
Slayer1904's Avatar
Originally Posted by BuggyKing
my current setup.
Novak 13.5 brushless
75/25 on the gearing
30 Degree front castors for more turn in
Trailing Arm spindles instead of GT2 fronts
Front 3 hole pistons
32.5 Losi shock oils
Rear 4 hole pistons
25 Weight Losi Oils
150k limiting front
60k limiting rear
Blue springs front and rear
3 degrees of anti-squat
M3 Bowties all around with
AKA foam inserts
Racer Edge 0.5 degree toe in hubs
Front 3 washers under ballstuds
Rear 2 washers under ballstuds
T4 CVD's
100k weight in diff
1 degree of toe-out
0 degree of camber
Battery in middle of chassis for a more neutral setup
Arms front level
Rear at dog bones level
I raced with you this past Friday @ OCRC and i've gotta say your truck was very fast all night.
Had a great time racing with you guys hope to make my way back up soon.
Slayer1904 is offline
