Old 04-01-2009, 12:49 PM   #1
Default Rustler xl-5 king pin
Does anyone know whether there is a heavier duty kingpin available for the rustler xl-5? They seem to get bent very easily.
ianhawk is offline   Reply With Quote
Old 04-01-2009, 03:49 PM   #2
y2kgtp's Avatar
Trader Rating: 35 (100%+)
Send a message via AIM to y2kgtp Send a message via Yahoo to y2kgtp
What are you hitting? it's 2.5MM stainless steel.....
"Yes my car is technically illegal, but still its either just as fast or slower than any other car on the track so whats the issue with it being illegal?"
y2kgtp is offline   Reply With Quote
Old 04-01-2009, 04:51 PM   #3
ta_man's Avatar
Trader Rating: 151 (100%+)
No one makes a heavier kingpin. Except me.
What I did is take one of the screw pins for the rear inner A-Arm pivot and cut it to proper length to replace the stock kingpin. Then very carefully (very very carefully) ream out the hole for the existing kingpin in the carrier and steering knuckle until the larger screw pin fits. I first did this about 6 or 7 years ago and haven't bent one of these heavier kingpins yet.
I use a pin reamer (a machine tool) to gradually enlarge the holes and then finish it with chucking reamers starting at .121" and going up until the pin fits easily but with no slop.
You can try it with a 1/8" drill bit, but you might not like the results after you are done.
ta_man is offline   Reply With Quote
Old 04-01-2009, 05:09 PM   #4
Not hitting anything! I think it is from doing cartwheels!
