HoBao Hyper 9E thread
#1232
i hope so,not my fault,what would cause it to overheat,running a 15t pinion,stock spur gear,reedy 14.8v lipo 4s 5000mah 40c,any ideas guys.....
#1234
if it has overheated or shorted do you think castle will replace it under warranty?i only got it 23rd december.also this was only my second run.first run was only for about 5 minutes,2nd run problem happened after about 15 minutes.
#1236
i didnt get a receipt but i know the owner of the modelshop well so i will be calling in tommorrow,also just looked on castle website and they give a 1 year warranty,thankfully.9e was flying as well,handling was excellent,cant wait to get it going again,only thing i will be worried in case it does it again.
#1237
what did you have your punch control and timing set at on your castle esc?.
#1240
Where do you buy those sheets of carbon fiber and what do you cut it with?
#1243
just thinking,you guys with mamba moster setups in your 9e,do you have any holes cut in the front of the shell for air intake to cool the motor and esc down?.
#1244
Guys, I will leave here a picture of how it turned out my latest amendment to h9e, with this modification the car under his weight and increase rigidity.
I few weeks ago that I am using it and gave me very good result if you can give me any suggestions are welcome
I removed the battery box in order to place the battery in another place and it is so well balanced the car less than 15 grams of difference between wheels
Greetings, I hope you like it
