HoBao Hyper 9E thread
#1051
i am looking for a support for my castle 2200 motor in my hyper 9e,does anyone know if the losi motor brace would help,item-losa4462.
#1052
What is the big deal about a "brace" under the motor. I have had about 10 converted 1/8th scales and never used a support under the motor. Never broke or bent a mount, what I have seen however is someone using a "support" had enough chassis flex to snap the bottom mounting screw off in the front of the motor.
#1053
only kooking for a motor support because the 2200 is a long motor and i have heard a couple of people say they have stripped the screws holding it onto the motor plate,
#1054
#1056
Use good quality fasteners, make sure they are tight and let the chassis flex its normal way, you will NOT have any thread problems.
Quality is the key, now days, you only get what you pay for......
#1057
Well, after reading this thread for a week or so, I bought a Hyper 9e and a Tekin RX8/1900kv combo. Good thread guys, keep it up....lots of great info! Definately helped me in my decision making process for a 1/8th electric.
#1061
Hey guys, Brandon here from Elite RC..well many of you have demanded a motor mount well it has finally arrived, feel free to ask questions or post on my Thread.. More info and details on www.Elitercd.com
AVAILABLE NOW
Here are some pics of the mount installed on my buddy's(Tito) 9E
AVAILABLE NOW
#1063
would the hyper 9e motor mount fit a castle 2200kv?
#1064
That pinion looks aweful close to that elite mount. How in the world do you tighten the set screw on the pinion?!
#1065
Tech Legend
I am assuming that this cam is standard for all his motor mount sets. If so, then the pinion opening is accessed from below.
one thought, I wonder if you could have a slot or relief drilled in the motor mount and cam so that you could also access the set screw on the pinion from above?
Push comes to shove, could do another hole in the chassis to reach it.
