HoBao Hyper 9E thread
#4231
tomorrow i will post pictures and i only mount my eletronics today on the chassis... i have checked diffs too and only tomorrow i will drive it!!
so far i like alot the displacement of things no the chassis , and seems everything pretty solid and well balanced!!
is is incredible that hyper launch this car on 2009 and still today only tekno eb48 seems to get close to this displacement. having this on my hands make me think that pretty almost other cars look conversion and not electric cars from scratch...
let´s see the handling tomorrow on track.
greetings from portugal
#4233
Just ordered the tekno sidegaurds..... Still waiting on the other bits I've ordered, but that's because I'm in the uk......
#4234
What are a good lipo 2s recommended to run? Want to buy a few more... What are you guys using? After good quality.... Thanks
#4235
Can a few off you put a couple of pictures up with all electrics & battery's installed please... Thanks.
#4237
anyone have a good solution for hyper 9e leaking diffs issue?
i discover mine comes with all the 3 leaking... i refill them and all gaskets are good but it leaks again even without running...
thank´s
thank´s
#4239
i will try that method and if amain have that ace hardware i will buy from them!!
thank´s for the help!!
greetings
#4240
I can't remember the part number, but I know people were using a Losi diff shim to put more pressure on the o-rings. This seemed to fix the problem. I will look and see if I still have the parts bag in my pit box.
EDIT: I went back in this thread and found it, part# LOSA6356 Make sure you are not over filling the diffs
#4241
hello!! i have to use only the losi shim without ofna stock one correct?
thank´s for the help.
#4243
I however noticed that even with this fix my diff ended up leaking . Reason I believe being that the o ring swells and doesn't seal the out drive anymore. Hence now using smaller inside diameter but thicker o ring working good for me.
#4244
The idea with the losi shim is to increase pressure on the o ring. Therefore you would add it to the existing setup. So concretely keep the stock shim as well.
in last case i will use grease instead oil.. i have several greases from BMW(my work) and i will test them also...
thank´s
#4245
finally some pictures of the car:
the last picture are orings from lrp that have almost the same specs as stock diff ones. i try this ones next time and see if still leak anything from diffs...
i also want rear and front cnc plates and center shaft cvd style, and tekno mudguards.
at rest all things seem pretty good balanced from stock....
shocks are lrp big bores and they are handling alot better than stock ones so far...
traction of hyper 9e is insane mainly of the rear of the car!!!
