HoBao Hyper 9E thread
#4216
As for the lipo's this is where I get a bit confused, I have 6 lipos that came with the buggie, which takes 2 lipos at a time.....
2x team overlander 2s (6500 25/50c)
2x turnigy 3s (5000mah 40/80c)
2x turnigy 3s (4000mah 40/80c)
After looking on the net, am I right in saying if I run both team overlanders, that's 4s
And likewise the turnigys,running both means they would be 6s?
Cheers Roy.
#4217
Once the sideguards are installed, you'll then have the possibility to install Velcro on the body to stick the chassis ! Even better for keeping things clean in there.
You are correct about running LIPOs in pair.
Man , 6S is going to be uncontrollable ;-) I have hard time with 5S same setup as you ;-)
#4218
#4219
You can set the settings to minimum, but on 6S the engine+ESC will get hot from my observations on 5S and you'll probably go too fast and tumbling will cause more damages than on 4S for exemple. + The differentials will need more care, probably higher density oil to protect them of the explosive punch of the 6 cells.
I say, try it first ... but for the 1st year you might be better with 4S, this HYPER 9E is pretty fast !!!!
My 2 cents.
My 2 cents.
#4220
I haven't run the 6s so if I want to get some 4s what would you guys getting for this buggie cheers.
#4221
A couple of tips from having had hyper 9e's for the last 4 to 5 years :
Once you have the Tekno side fitted, I'd cut out the outside edge of the battery box. This will give you a lot more battery choices as the stock box is a little narrow.
Check the length of the screw joining the rear chassis brace to the motor mount. Use as long as possible to fit in the thread but not too long of course ! There is a lot of stress in that area and eventually (so better later than sooner), the hole in the motor mount will be oval..(that's when it would be nice to have an Elite RC mount ready to fit too - but these have some downside too as the access to the center diff is more difficult).
Same comment for the screws in the front and rear bulkhead : maximize the thread available using longer screws.
I'd also put a piece of foam under the end of the motor so it doesn't hit the chassis too hard yet allow for some flex.
Enjoy ! This is a great Ebuggy whose layout remain very up to date (just compare with the latest tekno..) - front arms are a little weak I'd say now that I could compare with Losi/Kyosho's.
#4222
postie90: if you don't need the spare STEEL DRIVE SHAFT (indeed , your H9e already has it, lucky for you) I am willing to buy it, let me know
...but EricHobby would be willing to remove it from you order and refund it, contact him and let us know
I suppose he have not shipped it yet
#4223
#4225
Checking the pics you posted (wow.. that's brand new !), looks like you already had the updated center drive shaft (part 89339 in your order) and the steel diff mounts - so that's a last 'generation' Hyper 9e you got there. Very good !
#4226
Spares maybe ?
- Rear wing (2 pieces)
- Front sway
- Shock caps
- Tires (I love having the choice: Road Rage (on-road) , Duratrax Posses C2 [multitude good and cheap alternatives here] (race track) and Duratrax Lockup (extreme off-road)
- Wheels
- Tires glue
- Wheel nuts (i lost them quite often)
other members might have also suggestions...
What do you think ?
- Front sway
- Shock caps
- Wheels
- Tires glue
What do you think ?
#4228
i will receive a used hyper 9e tomorrow.
what advices for a new hyper9 driver?
it will run a hobbywing sc8 at 4s with turnigy 4 poles 1900kv..
#4230
RE motor foam bumper : see picture - just a small piece at the end.
