HoBao Hyper 9E thread >
Old 06-26-2013, 09:08 AM
  #4186
MaximeRoy77's Avatar
Thanks !
Another question, we are running hot:
Xerun 1800KV
5S 40C lipo
xerun 150a
Pinion: 15T
Stock spur
Would you consider a higher pinion ???
MaximeRoy77 is offline
  #4187
Thanks !
Xerun 1800KV
5S 40C lipo
xerun 150a
Pinion: 15T
Stock spur
Old 06-26-2013, 11:11 AM
  #4188
kufman's Avatar
Originally Posted by MaximeRoy77 View Post
Thanks !
Xerun 1800KV
5S 40C lipo
xerun 150a
Pinion: 15T
Stock spur
You are over geared for 5S operation. The pinion you are using would be close for 4S operation. Maybe around a 12 for 5S?
kufman is offline
Old 06-26-2013, 11:29 AM
  #4189
Oh ! Thanks
Can I run lower than 14T on stock motor mount ? or Elite RC one ?
Other solution would be high-T spur gear ?
Any specific recommendations ?
Old 06-26-2013, 11:33 AM
  #4190
elex300's Avatar
Trader Rating: 106 (100%+)
What aftermarket bodies fits this car?
elex300 is offline
Old 06-27-2013, 05:50 PM
  #4191
kufman's Avatar
Oh ! Thanks
If you are running a 42mm motor, 14 is about the lowest you can go with any of the motor mounts. I am not aware of larger spurs that fit the 9E diffs. It would probably be easiest to go to 4s or get a lower Kv motor for 5S.
kufman is offline
Old 06-27-2013, 06:23 PM
  #4192
Losi 8ight bodies will work. The front of the shell will need some trimming to make it fit right. I'm running a bulldog body with velcro on the sides and mudguards and it fits pretty good. I also modded the front mount to sit lower, but I'm not sure it was really neccesary.
Battery fits pretty well too (4s), forward outboard corner does hit the shell though.
I have a Bitty Designs Force and Fighter for the Losi 8ight on order, I can let you know how those turn out when I finish them if your interested.
Zombie Kung Fu is offline
Old 07-06-2013, 07:56 PM
  #4193
I've run at a race track today and bent 2 drive shart (aluminium full lenght) and was wondering, a part my driving qualities, what can help reducing that ?
Does the CNC Center Rear Chassis Brace help ?
  #4194
I've run at a race track today and bent 2 drive shaft (aluminium one) and was wondering, if you we don't discuss my driving habilities, what can help reducing that ?
Or I should go back to the Hyper 9 (E Version) Steel Uni Center Drive Shaft
Old 07-07-2013, 06:57 AM
  #4195
kufman's Avatar
The main problem with the original drive shaft is that it was too long and didn't have any room for chassis flex. The universal one that you posted was shorter and was supposed to fix the problem. The rear chassis brace didn't do anything to fix the problem since the flex of concern is in front of the center diff.
kufman is offline
Old 07-07-2013, 07:09 AM
  #4196
OK thanks,
So replacing the aluminium one
with the Hyper 9 (E Version) Steel Uni Center Drive Shaft
one would help ?
From what I understand , right?
Old 07-07-2013, 07:21 AM
  #4197
kufman's Avatar
I never tried it but that was the general consensus in earlier pages of this thread.
kufman is offline
Old 07-07-2013, 07:31 AM
  #4198
Great, will report back later.
Old 07-08-2013, 05:42 AM
  #4199
... and does this part would help, since you mentionned that the flex was coming from the front ?
Hyper 9 CNC cut Front Top Plate
Old 07-08-2013, 05:43 AM
  #4200
