HoBao Hyper 9E thread
#4171
It is not a direct fit and the hub needs to be modified for thickness. I was able to do it with a dremel and a cordless drill. I don't have any pictures of the one I made and unfortunately I can't take any since I sold the car. I think the only thing that needs to be modified is the area around the o-ring on the inside of the hug. There is a shoulder that sticks out to far. It needs to be made smaller as does the shoulder that the bearing sits on.
#4175
hey guys i haven't raced in almost 3 years do to a track closing. i have a tone of hyper 9 parts from my days of running nitro. my problem is the new track doesn't have a nitro class. i'm looking for a roller or for someone that has some extra parts that i can use to convert it. the wife said i can only spend $300
i thought maybe some of you guys could help me out
#4177
Some guy told me that If i am running the H9e on 5S I should go with 10,000 oil in all differentials.
I did it and now the car is really slower, less explosive, like running with a brick on the top.
I was thinking going 5000 in the center diff to help the engine ?
What do you think ?
What do you think ?
#4178
What do you think ?
What do you think ?
#4179
What do you think ?
What do you think ?
#4181
Doesn't matter if you are bashing or racing, the setup on these cars really doesn't change. What drives good on the track, works good on the road or in the back yard. I both bash and race and I don't change the setup on my cars. Real heavy diff oil in all three diffs is going to make the car drive like a dump truck no matter what surface you are on. If you want a little bit more full time 4wd drive feel, go heavier on the center diff but not the others.
#4185
My MMM is solid to my chassis mounting this way and my track has big jumps and hasn't come off.
