HoBao Hyper 9E thread
#3871
#3873
It's an earlier pic of the car from January indoor racing, but I still have it mounted the same way. This car is AWESOME! outside as well!!!! I used the personal mount that came with the car to mount the antenna. If you take an old piece of 12g. mtr wire and skin it you can use its rubber housing to cover the antenna wire til it gets to the mount.
#3875
Nice work Mike-
Where did you purchase the motor wire guide? I also like your placement of the receiver. This is truly excellent work.
#3876
#3877
WHat in the [email protected]$# did they use for thread lock on the center driveshaft ??
#3880
#3881
#3884
Did any of you tried both Hyper 9E and MBX6 Eco?
What are the differences between both?
#3885
One big difference between the Hyper and the others mentioned is the layout of the electronics. The others have radio tray/boxes that are basically carried over from their nitro versions. The Hyper is narrow and has the motor and battery mounted as close to the center as possible and also has the motor as far back as possible and the battery as far forward as possible. This design, (which works really well) leaves very little room for the other electronics,when compared to other cars mentioned. But, if you like to be a little creative when mounting you receiver,esc, etc. YOU WILL NOT BE DISSAPOINTED WITH THIS CAR! I'LL RACE IT TIL THE HYPER 10E COMES OUT
