HoBao Hyper 9E thread >
Old 01-01-2011, 07:54 AM
  #3166
Originally Posted by wjmiller3 View Post
I went to Mikes in Houston yesterday and ran about 6 packs of 4s through the 9E for the fist time. Wow! If I was buying lipos from start I prabably would go 3s, but since I already have two 4s lipos I think I will stick with that. It was getting to top speed on the straight with the 4s with the 14t just about the time I had to get on the brake. And there was nothing there yesterday that could pass me in the straight. Being my first outing with a 1/8 buggy I could not keep up very well with the seasoned guys after that, but it was fun! And I found out loctite is worth its weight in gold!
Neither of the hobby shops here on the north side of Houston carry Ofna parts, and Tower doesn't really either. So do you buy parts straight from Ofna or is there a better online place? Thanks
Nitrohouse
Whosold is offline
Old 01-01-2011, 08:15 AM
  #3167
MindThoughts's Avatar
Trader Rating: 19 (100%+)
Default Happy New Year Everyone + Where To Buy Your Hyper 9E Parts.
I highly recommend NitroHouse. Great prices and great customer service. Plus- one of the designers of the Hyper 9E is often available to answer any setup questions you may have- Tim Bump. I purchased my first Hyper 9E from NitroHouse- and I buy most of my parts from NitroHouse as well.
PS. Happy New Year Everyone
This is a great thread- and the Hyper 9E is still my favorite 1/8th scale 100% purpose built for electric- buggy. And I'm very grateful that Ofna continues to offer upgrade and new option parts such as the new Universal Center- Solid Steal Drive Shaft- and the new 42Tooth Derlin Non-Metal Spur Gear as well.
And special thanks to DJ Ofna customer service tech for helping me with my first Hyper 9E with setup tips and advice when I first purchase the Hyper 9E when the buggy had just been released for puchase. I never thought I could be so happy with a 1/8th scale buggy- durability- extremely simplistic design- extremely efficient and centralized- center drive line- and very well balanced.
May we all have a great year of rc racing
MindThoughts is offline
Old 01-01-2011, 09:27 AM
  #3168
HYPERBOY's Avatar
Originally Posted by Chuck 21 View Post
Good info. James, the pictures are about worthless though as some are
blury & their to small to see anything...Nice try though...
Also I don't understand what the 3X6 cap screws do or where you put
them in the C hubs...
Thanks for the part numbers for the hop ups. Tim Bump told me when
I ordered my Hyper 9 that no hop ups were needed for the buggy as
it is bullet proof right out of the box. I hope he was right because I'm
racing at two tracks this weekend for the first runs on my new buggy
& no one has parts for the Hyper 9 anywhere I race...
I didn't like the looks of the plastic shock caps but Tim claims they
don't break...We'll see...
If you look at the backside of your c-hub there is an extra hole right where the tie rod hit at full turn, thats where the screw goes, I had a picture up but i'm not sure what happened.
HYPERBOY is offline
Old 01-01-2011, 01:08 PM
  #3169
RCMits's Avatar
Trader Rating: 29 (100%+)
nitrohouse
RCMits is offline
Old 01-01-2011, 10:32 PM
  #3170
Grouchman's Avatar
Trader Rating: 76 (100%+)
Originally Posted by HYPERBOY View Post
Here is My Hyper 9E, starting set up and some helpful Team Tip's from DJ.
Basics:
Hyper 9E
Castle 2200 Kv
4s
Upgrades:
OFN28208 CNC shock caps
OFN29148 CNC spring retainer
OFN29147 CNC rear upright
OFN29331 CNC chassis brace
OFN10994 serrated wheel nuts
Tekno mud guards
Snr chassis bracew/esc plate
Setup:
Front
7K Ofna
45wt Losi
Silver Xray spring
0 Toe
0 Camber
Arms just below level
All other setting stock from box
Center
7K Ofna
Rear
5K Ofna
40wt Losi
Silver Xray spring
0 Camber
CVA's level
Team tips:
-Trim the nose piece of body to allow for easier access to sway bar and give sway bar clearance(pic below)
-Use reverse thread screws(OFN28208) on front lower shock to prevent back out.(pic below)
- Use 3x6 cap head scres in front C knuckle to prevent oversteer which will cause CVA to pop out when landing and turning at the same time.(pic below)
-Boil you wing, this will help keep them from breaking.
-Drill your top plate and run a longer screw with a locknut for the front body post, this will prevent it from backing out during a race and finishing like an aligator.(pic below)
-Run foam under the motor to take stress off motor mount and screws(pic below)
Hyperboy, where did you get the upper brace from and what brand is it?
Grouchman is offline
Old 01-02-2011, 08:39 AM
  #3171
HYPERBOY's Avatar
I have all of my hop ups listed, which one are you referring to?
Upgrades:
Tekno mud guards
Snr chassis brace w/esc plate -------maybe this one?
You may need to do a little tweaking with this setup and indoor but I am having very good results with this outdoor. First race is January 15th at Revelations for their annual Airtronics Winter nationals
HYPERBOY is offline
Old 01-03-2011, 12:41 PM
  #3172
Thanks James,JT at Nitro House said he read your post already and explained
it to me. We both decided it was not really needed..
Thanks again for the reply...
Chuck 21 is offline
Old 01-03-2011, 01:32 PM
  #3173
Heres how my first 3 days at the track went with my Hyper 9..
First off I'm running Tekin 1900 & RX8 with 4S..
Test day Friday not so good. In less then 2 batteries I broke a front arm.
(Good thing I took heed in what many have posted here about the front
arms snapping like pop corn) I had ordered spare arms (thanks guys)
What really pizzed me off about that was I never crashed & never hit
anything. All I did was nose into a few jumps at low speed trying to find
some timing through some jumps and I was being very timid about driving
this fire breathing monster. Then the end to my day came from a guy
jumping the pipe with a Truggy hitting me head on (low speed) and the
shock cap broke clean off. (no parts around here for the Hyper) but my
local hobby shop had some O'Donnell 17mm shocks hanging on the wall.
I bought the shocks because they came with mounts for the shock tower.
I screwed the O'Donnell shock caps on and put their mounts in my shock
tower (all was good again)
So test day was all shot to h*ll... (no biggie)
First race day it ran OK" but it was hard to tell because I was affaid of
the dam thing. (I've raced nitro 1/8th buggies for years and these are
nothing like those pussy cats) I did manage to TQ by a lap though"
In the main I found out these E buggy drivers are no friendlier in mains
then the nitro guys and they beat the living snot out of me LOL" I finished
in 3rd 7 seconds behind the leader...
Second race day was at 702 in vegas on thier 60 X 80 foot indoor track.
This was very intimidating to say the least. I sucked (POINT BLANK")
by the end of the main I got it slightly figured out and turned fast enough
lap times to be competitive with the winner. (to little to late")
Over all the first day I give the Hyper a zero on a scale of 1 to 10 for
being a strong tuff buggy. I've never in almost 30 years of R/C
racing seen anything break so easy. All my 1/8th nitro buggies were 99%
bullet proof (except my Thunder Tiger) which I threw over the fence real
quick. To me the break in my arm looked like a defective arm so I'll hang
on to the Hyper for a while longer. Plastic shock caps on a supposed race
buggy is just plain stupid IMO"
By day 3 I give the buggy a 7 out of 10 for a strong tuff buggy. We'll see
how that goes after a few more race days??
Over all it works OK" but mine pushs like a dump truck right now. I know
this E thing will take time to work out after being a nitro buggy driver
for so long, so I'll work on the pushing problem I caused because the
thing was so loose out of the box I went 180 the other way to learn to
drive it. You can't learn anything about driving a new car if it's doing
donuts every corner LOL" So I'll work on more steering once I'm more
comfortable driving it..
Just in case some people think I'm bashing the Hyper 9, I'm not. I will
put the time in to give it a fair shot until it proves to be as unreliable
as my Thunder Tiger was. (I really think the arm was defective and I
saved it in case the boys at Nitro House want it back?)
I'm going to Nitro House's home track this weekend (West Coast) &
hope to get to meet some of the guys...
Chuck 21 is offline
Old 01-03-2011, 01:47 PM
  #3174
HYPERBOY's Avatar
If you come down, race Saturday....Sunday is the supercross race and there were 240 entries 28 heats and a 12am finish time.
Wish I could meet you but right now I have to much motor for ANY indoor track plus Team SUPERHYPER will be a Revelations racing.
HYPERBOY is offline
Old 01-03-2011, 02:06 PM
  #3175
To bad, we're going to be there for West Coast practice Thursday,
race Friday, Sat to round one Anaheim Super cross (motorcycle race),
Sunday back to West Coast for racing again...
Fun" Fun" Fun"
Chuck 21 is offline
Old 01-03-2011, 05:23 PM
  #3176
jboquire's Avatar
Trader Rating: 21 (100%+)
I recently purchased a Hyper 9e but I'm experiencing what seems to be radio interference, these are the electronics used:
Airtronics M8 with Spektrum module
Spektrum SR3500 receiver
CC Mamba Monster esc mounted on the chassis using SNR carbon fiber esc mount
CC 2200kv motor
I already tried another receiver and also added a Novak capacitor and no improvement. Is it possible that the harmonics produced by the metal spur and the pinion are interfering with the radio system?
Thanks in advance, jb
jboquire is offline
Old 01-03-2011, 06:13 PM
  #3177
HYPERBOY's Avatar
You should check for any wire cuts
Next start a step by step process:
unplug the servo try it
unplug transponder
You could remove the carbon fiber and try it
HYPERBOY is offline
Old 01-03-2011, 07:18 PM
  #3178
jboquire's Avatar
Thanks James, I'll try that.
Jb
jboquire is offline
Old 01-03-2011, 09:26 PM
  #3179
balistic's Avatar
Trader Rating: 113 (100%+)
Are you saying you need motor or a battery? I have either for you if you want to do West Coast.
balistic is offline
Old 01-03-2011, 10:41 PM
  #3180
Registered User
Trader Rating: 8 (83%+)
HEY GUYS HYPER 9E WITH MOOSRACING CF CHASSIS FOR SALE!!!
COMES WITH:
UNIVERSAL CENTRE SHAFT
ALL ALLOY HOP UPS-shockcaps,rear hubs,front brace and etc
2 PIECE WING MOUNT
HOBBY WING ESC AND HOBBY WING 2250KV MOTOR
HITEC 7995TG SERVO
Plus tons of extras
RACED FOR A SEASON AND EVERYTHING IS IN EXCELLENT WORKING ORDER.
Finished 2nd in my local racing championship
Asking $500+ shipping (if not happy on price make an offer)
Please email for pics [email protected]
regret full sale as my wife has just given birth and also because I have just purchased an Xray t3 11 on road car to race for a season.
shano83 is offline
