HoBao Hyper 9E thread >
Old 12-28-2010, 02:09 PM
  #3136
Originally Posted by Arigato View Post
Chuck, with the motor you're running, just get a couple of these:
http://www.promatchracing.com/proddetail.php?prod=3806
They're light, inexpensive and will easily last a 10min. main. Plus, since the company is located in Arizona, you'll probably get them very quickly.
Easy to get here, Jeff the owner of Pro Match is at the track here in Havasu
every Saturday because Pro Match is in Havasu...
Chuck 21 is offline
Old 12-28-2010, 02:35 PM
  #3137
Registered User
snrscion's Avatar
Trader Rating: 21 (100%+)
Originally Posted by RCMits View Post
MMP? really?
I shall check out the MMM+1900 suggestion.
How many cell are you plan on running? I run 3s with MMP and tekin 1900 no problem 12 min and no heat issues.
snrscion is offline
Old 12-28-2010, 02:44 PM
  #3138
fallguy's Avatar
Originally Posted by Integra View Post
Your 9 felt Great that small time i did play with it, On 3S its fine on the infield but the straight is where it showed its weakness....Castle has boost/timing advance stuff now don't they ?
i could of geared it up as well.. after 10min of running its cool.. no heat at all. Im not too sure if Caltle has boost yet.. but that would help as well.
I have turnigy hard case 4cells for it now
fallguy is offline
Old 12-28-2010, 03:08 PM
  #3139
balistic's Avatar
Trader Rating: 113 (100%+)
Originally Posted by HYPERBOY View Post
If you are going to run indoor only
Get the MMP and use a Tekin 1700, this allows you to use sensor setup which is MUCH smoother.
Or run a MMM with a Tekin 1900
I have finished my Hyper 9E and should have a write up with some team tips this week!
Why the MMM with the 1900 and not the MMP?
3S or 4S on the MMP 1700?
balistic is offline
Old 12-28-2010, 04:52 PM
  #3140
HYPERBOY's Avatar
If he wants or has an MMM its an option
3s on MMP
HYPERBOY is offline
Old 12-28-2010, 05:21 PM
  #3141
balistic's Avatar
3s on MMP
I have an extra MMP and a 1700 but hadn't thought of the two together, I was going to use the 1512 1.5Y 1800.
balistic is offline
Old 12-28-2010, 05:29 PM
  #3142
On a tight 60 X 80 foot track like 702 would it be possible to run a 2S
with the Tekin 1900????
I'm not a big believer in speed winning races, I win plenty at Havasu &
702 with the slowest 2WD SC truck on the track...
Thanks for any input'
Chuck 21 is offline
Old 12-29-2010, 10:31 AM
  #3143
balistic's Avatar
The question would be gearing, I don't know what the biggest pinion you can run is? I know I have had a 20 on my 1700 with 3S and it was still fast enough at WC, I have a 25 on my LST and it is huge.
What I was talking about earlier was the weight advantage you would have by running the 2S with the 540 4 pole Nue Castle motor and a 10th scale ESC as a package. some of that would go away, 5 to 6 oz by using the 1/8th scale motor. couple that with an oz or two from the ESC and another 6oz from a 3S or 10 oz from a 4S. This combo will be 14 to 18 ozs lighter and have good controllable power.
This has got me thinking about carbon this and that's and taking some of the aluminum upgrades off to run 702.
The only time I was there I was in aw with the guys truing to run full boogie 4S monsters on that little track
balistic is offline
Old 12-29-2010, 12:12 PM
  #3144
HYPERBOY's Avatar
Went to Revelations last night with team " SUPERHYPER" ...that's what I call them Dj,Gauge,Mark and a couple others.
Got to run the buggy for the first time and it is AMAZING......I doubt there was a faster buggy down the straight and it had the perfect balance of traction and steering.
People said they could hear me laughing over the nitro cars every time I launched it off the GIGANTIC quad.
I will post my write up with team tips tomorrow afternoon so keep an eye out!
HYPERBOY is offline
Old 12-29-2010, 01:12 PM
  #3145
-R2-'s Avatar
We were being entertained "Quad-master"
-R2- is offline
Old 12-29-2010, 01:39 PM
  #3146
HYPERBOY's Avatar
Friday I'm doing a backflip
HYPERBOY is offline
Old 12-29-2010, 02:07 PM
  #3147
-R2-'s Avatar
I thought you did that on the front straight?
-R2- is offline
Old 12-29-2010, 03:13 PM
  #3148
HYPERBOY's Avatar
No that was the first turn .. That's whats happens with 100% throttle and 40% brake, your car can't stop so I resulted to crashing as my brake.
HYPERBOY is offline
Old 12-29-2010, 08:19 PM
  #3149
I just bought a 9E and it should be here in a couple days but I have a question. I didn't have time to look through the 200+ pages of this thread but I am new to 1/8 scale and I was going to run my MMM/2650 out of another vehicle I have and as of now plan on running 4s lipo. What would be a good starting point for a pinion? I run on a large 1/8 track (Mike's in Porter, TX). Thanks!
wjmiller3 is offline
Old 12-29-2010, 09:49 PM
  #3150
Integra's Avatar
3S might be more suitable for your 2650....For a 4S set-up your looking for 1800-1900kv range.
Integra is offline
