HoBao Hyper 9E thread >
Old 11-21-2010, 01:37 PM
  #2956
fallguy's Avatar
will the nexx body fit on the hyper?
fallguy is offline
Old 11-22-2010, 07:03 PM
  #2957
Jube's Avatar
Trader Rating: 43 (100%+)
No, it's too narrow for the hyper.
Jube is offline
Old 11-22-2010, 07:48 PM
  #2958
reracer's Avatar
Anybody know who has any BittyDesign bodies in the USA?
reracer is offline
Old 11-24-2010, 10:46 PM
  #2959
Thought I would share a body wrap I've been working on. They are for sale on the bay.
KyJoe340 is offline
Old 11-25-2010, 09:05 AM
  #2960
Finally got a chance to weigh my H9, and with Proline rims and rubbers, stock body, teknoRC mudguards with velcro, Turnigy 4S 5000mAh pack and a Tekin RX8/T8 combo I end up at 3623 grams
Is this ok?, seems a bit heavy to me but hey I am used to Nitro cars
vic viper is offline
Old 11-25-2010, 09:11 AM
  #2961
Jube's Avatar
Originally Posted by vic viper View Post
Finally got a chance to weigh my H9, and with Proline rims and rubbers, stock body, teknoRC mudguards with velcro, Turnigy 4S 5000mAh pack and a Tekin RX8/T8 combo I end up at 2623 grams
I think your scale is off Vic. For instance ROAR legal is 3200g and it's really tough to get down that low without doing major things.
Jube is offline
Old 11-25-2010, 09:28 AM
  #2962
Ah, my bad, its 3623 grams, editing now!
Old 11-25-2010, 10:40 AM
  #2963
SnoopMaxx's Avatar
My Hyper 7 is around 3500g
Morten
SnoopMaxx is offline
Old 11-25-2010, 10:46 AM
  #2964
Morten
With what kind of pack?
Old 11-25-2010, 10:54 AM
  #2965
reracer's Avatar
That's just shy of 8lbs, which is on the heavy side. My car with a 5000mah 4s is at 3476(7.66lbs) race ready. That's with my tank Losi speedo. I run a smaller 3300mah battery for qualifying runs, and some short mains. That takes 170 grams off down to 3306(7.3lbs).
With an RX8 and the CF chassis I should be able to get it down to under the 3200 ROAR minimum weight.
reracer is offline
Old 11-25-2010, 11:03 AM
  #2966
Jube's Avatar
That's fairly avg I would guess. I pay close attention to tire, foam, and wheel weight. As well as batteries. My buggy weighs in at 3350ish rtr with HoBao Fire L tires, HoBao foams and Ofna ultra light wheels. That's with a sub 400 gram battery also.
Jube is offline
Old 11-25-2010, 11:14 AM
  #2967
@reracer, what have you done to keep the weight so low?
I havnt done anything to make my car lighter because I think you need to do some serious stuff to cut some noticeable grams..
Just weighed one of my packs and they weigh in at 591g
Old 11-25-2010, 11:34 AM
  #2968
Jube's Avatar
I would say his 3300 4s is close to 300g lighter than yours. That's over 10 ozs
Jube is offline
Old 11-25-2010, 01:30 PM
  #2969
reracer's Avatar
-My 3300mah packs are 316g.
-I run the 16mm Jammin shocks with the aluminum post, which are lighter.
-I replaced all of the steel pivot balls with the optional CNC aluminum ones.
-I use as many aluminum screws as possible, and some titanium ones. Not as many as Kortz though.
-My battery box is cut down and some of the bottom has been milled out.
-I run a custom CF drive shaft with a uni front. It's the same weight as the stock aluminum one though.
Keep in mind that I have the optional wing mount,the EliteRC motor mount, custom rear chassis brace, both front CNC chassis braces along with a custom speedo/servo mount. All these things added some weight.
reracer is offline
Old 11-26-2010, 05:36 AM
  #2970
I am a happy Mugen driver, but I am also interested in trying out a Hyper 9e. If I buy a new Hyper 9e in the current version, could you please briefly list the hop-ups that I would need to have a durable buggy? Thanks...
stigno is offline
