HoBao Hyper 9E thread
#2416
Sounds good, thank you for that info T4. I really very much appreciate it
And I will be quite careful with gearing and watching my temperature(Motor, ESC, and LiPo, and All wires and connectors). And I'll be sure to let you and everyone on this thread know how testing goes with this motor(and MMP esc combination). This is fun
You might have to mod up one of those SC10 42T delrin spurs in order to give yourself enough room to run that motor.
#2417
Thank you for the information Ezrem. Yes I do use the Elite-RC Motor mount. And I agree that I should start out with a small pinion gear. This is why I put a 9Tooth RC Monster Pinion Gear on the Hyper 9E. Keep in mind I'm using the Losi 43Tooth Spur Gear. It's the Plastic Outer(Gear Teeth), with metal/steel center that will not warp as easy as the all plastic or Derlin spur gears. Though I'm interested in running the 42tooth derlin spur gear, I have no way of modifying that spur gear to allow the proper bearing to fit the gear. If I can find a way to modify the 42tooth derlin spur gear to fit my Hyper 9E, I will most certainly give that one a try as well. I'm not sure if a gear smaller than the 9tooth pinion will fit because I don't have a smaller gear than the 9tooth, though I can look into this. Although I think like you said, I may very well end up with a 12 or 13tooth pinion, both of which I do have by Hot Bodies, which is the recumeded pinion gears to use with the Elite-RC motor mount. It's just that Hot Bodies doesn't make a Pinion Gear smaller than a 12tooth, not that I was able to find on their web site.
I'll post some pictures up of my 9/43 tooth configuration, as soon as I find time to do so. should be soon though
#2418
shano- how much flex does your new chassis have compared to the stock Hyper 9e chassis?
#2420
#2421
#2422
#2424
thats the one
i will send you a PM , i'm interested in a few products for the Hyper 9e ..keep up the good work , i think your buggy looks awesome
#2425
Where is everyone getting the mud guards for the 9E like in the picture two replies up from this one? I have read about people using all kinds of modded guards but the one in that picture looks like it fits the 9E perfectly.
Thanks.
Thanks.
#2426
Use these:
http://www.teknorc.com/advanced_sear...keywords=guard
#2427
Guys,
A buddy of mine is looking for a USA (preferably) distributor of these mud guards he saw at the following link:
http://www.buggy-sport.info/index.ph...ud-guards.html
Anyone have any ideas where to get em ?
Cheers.
Cheers.
#2428
Guys,
Cheers.
Cheers.
These are quite nice. First time I've seen any type of rear arm mudguards for the Hyper 9. Also, I saw the bottom of rear arm mudguard, That's a first for me, I've never seen that type of mud guard for the bottom of a rear arm before now. Thank you for this information.
#2429
Guys,
Cheers.
Cheers.
A friend of mine fabricates lots of carbon RC parts for almost any vehicle. Pretty much the only thing he doesn't do is chassis. I am about to give him my buggy so that he can create some shock towers, mud guards, etc. I will let you guys know when he's ready to start selling carbon parts for the Hyper 9e.
In the mean time, feel free to check out his website: http://www.outfrontframes.com
