HoBao Hyper 9E thread >
Old 08-20-2010, 10:20 PM
  #2401
MindThoughts's Avatar
Trader Rating: 19 (100%+)
Default What are you talking about?
Originally Posted by kman16jr View Post
shocktowers,chassis brace,and the aluminum brace from ofna for the front,the conversion which mindthought's you know what i'm talking about
MindThoughts is offline
Old 08-20-2010, 10:22 PM
  #2402
T4 Razer's Avatar
Originally Posted by T4 Razer View Post
Besides the MMPro, Barry Baker used to run a novak sensored motor when e 1/8 was starting at OCRC. It is worth a try. I would just test the temp after a bit just to make sure you are ok.
Just in case, the Novak is a 2 pole motor so it will get hotter than other motors, that is why I would watch the temp closely at first.
T4 Razer is offline
Old 08-20-2010, 10:27 PM
  #2403
kman16jr's Avatar
Trader Rating: 56 (100%+)
pm me
kman16jr is offline
Old 08-20-2010, 10:29 PM
  #2404
Default 2 Pole Novak Motor vs ?
Please say more, I will also read up on this; but would like to know as much as you can say about 2pole vs 4pole vs? what does the pole count do to power, heat, torque, speed and anything else I missed.
Old 08-20-2010, 10:39 PM
  #2405
T4 Razer's Avatar
4 pole has more torque which is better for 8th scales. I am pretty sure there is more heat not significant if geared right for 2. A 2 pole generally has more rpm compared to the same exact motor that would have 4 poles.
I think thats it...
For your car I think you should be fine. Just get the gearing right.
T4 Razer is offline
Old 08-20-2010, 10:46 PM
  #2406
T4 Razer's Avatar
Dont know if you guys know about this car but... I for some reason got my hands on and own Atsushi Hara's 2007 (I believe) world's b4 that he won with.
T4 Razer is offline
Old 08-20-2010, 10:50 PM
  #2407
kman16jr's Avatar
Please post pics,i would love to see that car,lucky you got your hands on it.
kman16jr is offline
Old 08-20-2010, 11:02 PM
  #2408
T4 Razer's Avatar
Here it is: The motor plate and servo saver piece are clearly hpi purple. The tierods are purple but it is hard to tell in the picture because alot of the anodizing has worn off so it is like a blueish purple. The front arm brace had to be replaced a while ago because it was pretty worn and beaten.
Attached Thumbnails HoBao Hyper 9E thread-001.jpg   HoBao Hyper 9E thread-002.jpg   HoBao Hyper 9E thread-003.jpg   HoBao Hyper 9E thread-004.jpg   HoBao Hyper 9E thread-005.jpg
T4 Razer is offline
Old 08-20-2010, 11:09 PM
  #2409
Default 2 Pole Novak Motor. HV 4.5.
I think thats it...
Sounds good, thank you for that info T4. I really very much appreciate it
And I will be quite careful with gearing and watching my temperature(Motor, ESC, and LiPo, and All wires and connectors). And I'll be sure to let you and everyone on this thread know how testing goes with this motor(and MMP esc combination). This is fun
Old 08-20-2010, 11:15 PM
  #2410
kman16jr's Avatar
are your shocks threaded?And was the front hinge pin holder purple before you replaced it?If so then it might have been his car.I have the mag with his b4 in it somewhere so i can give you an exact answer soon.
kman16jr is offline
Old 08-20-2010, 11:21 PM
  #2411
T4 Razer's Avatar
Yes they are threaded. I believe the front hinge pin holder look the same as the tierods do now so I believe so. I know for sure it is because I know who it traveled from. It went from Hara to Jeremy Felles to a person I worked with at one time to me.
T4 Razer is offline
Old 08-20-2010, 11:22 PM
  #2412
kman16jr's Avatar
just checked my mag and you have THE HARA'S B4 you lucky bastard
kman16jr is offline
Old 08-20-2010, 11:26 PM
  #2413
T4 Razer's Avatar
jk I didnt know it even know it until I brought it to the track. I was just unsure about the year of the worlds he won which i guess is 2007.
T4 Razer is offline
Old 08-20-2010, 11:27 PM
  #2414
kman16jr's Avatar
I think it was 08 but could be wrong.
kman16jr is offline
Old 08-21-2010, 05:08 AM
  #2415
Registered User
Trader Rating: 8 (83%+)
Can anyone please tell me the weight of the cnc chassis please as I would like to compare it to my new chassi
shano83 is offline
