HoBao Hyper 9E thread >
Old 07-27-2010, 10:24 AM
  #2026
Registered User
snrscion's Avatar
Trader Rating: 21 (100%+)
Originally Posted by MindThoughts View Post
So, if I'm racing and use my own Personal Transponder, and use only one servo(steering) on my 1/8th scale buggy, I would want to use an external BEC, to help prevent potential glitching?
PS. If this is the case, this is consistant with what I've been reading. People having problems with glitching that an external BEC always, or almost always eliminates. Thus my original question stands. What BEC will be used, I should say; if one is to be used. That may be something Steve will or will not decide to add at a later date. If Steve wishes to chime in at any time, please do so(aka snrscion).
Well I usually don't run a BEC with my MMP but I do run a capacitor so my PT will work properly. Without the capacitor my PT tend to miss count laps.
snrscion is offline
Old 07-27-2010, 10:42 AM
  #2027
T4 Razer's Avatar
Oh yeah I remeber people say you can do that also.
PS: Steve, are the hypers still in customs, or when can I possibly expect mine? Thanks so much!
T4 Razer is offline
Old 07-27-2010, 11:51 AM
  #2028
HH
HH's Avatar
Default MMP BEC
+1
I run this voltage capacitor with my MMP because it's simple. You can make your own for about $2 if you can find the right size capacitor.
http://www.shopatron.com/products/pr...=NOV5626/135.0
I prefer this version of the MMP as it has solder posts similar to the RX8.
It comes with the internal BEC removed and no fan, both of which I don't use anyway.
http://www.amainhobbies.com/product_...ss-ESC-1S-LiPo
This is the BEC I use because it's small, lightweight, and has worked well so far.
http://www.amainhobbies.com/product_...Adjustable-BEC
I did have issues with glitching and my transponder missing some laps when using the standard MMP with the internal BEC.
Since I've been using the external BEC in combination with the capacitor it has worked flawlessly and I typically run 6s on outdoor dirt (Rev) setup for 20 minute mains.
I pushed it hard for 15 minutes trying to comeback from dead last this past weekend after getting hooked up with some plow donkey twice on the first lap of the A main and the car came off the track at under 130 degrees for the motor and just under 110 degrees for the MMP with no fan. I was running 6s with a T8 1400kv in "smart-sense" mode.
HH
HH is offline
Old 07-27-2010, 12:32 PM
  #2029
Registered User
snrscion's Avatar
maybe today or tomorrow.
snrscion is offline
Old 07-27-2010, 12:36 PM
  #2030
T4 Razer's Avatar
Alright cool
T4 Razer is offline
Old 07-27-2010, 12:37 PM
  #2031
Registered User
snrscion's Avatar
Originally Posted by HH View Post
+1
HH
WOW the MMP survived in an 1/8 scale without the fan, now that impressive.
snrscion is offline
Old 07-27-2010, 12:41 PM
  #2032
ronsand's Avatar
Originally Posted by ronsand View Post
Can some of you guys measure the diameter (OD) of the spur gear on the center diff?
Please
Regards Ronny
ronsand is offline
Old 07-27-2010, 01:10 PM
  #2033
lbckevin's Avatar
Trader Rating: 96 (99%+)
Steve...
I received a couple of the Castle BEC's at west coast raceway if you need one.
lbckevin is offline
Old 07-27-2010, 03:15 PM
  #2034
DanielC.'s Avatar
Trader Rating: 56 (100%+)
The internal BEC over current protection circuitry is supposedly too sensitive when powering high torque servo(s) such as the JR9100 S/T amongst others but the actual BEC is able to handle the loads. You simply need a capacitor as stated previously to get rid of voltage ripple when the over-amp protection kicks in momentarily. It's mainly an issue with 2.4 systems where they "brown out" or lose bind momentarily, so you lose servo response and throttle response for an instant.
Here's a video of my 8ight doing it (impossible to drive like this hence my bad driving... and lack of skill )
http://www.youtube.com/watch?v=OxMpYVaXKnw
Oh and also the ONLY Castle product I do not approve of is the CC BEC, I have had several fail on me and deliver full voltage to my servos. But your results may vary and I know of many who use them without issue.
IF ANYONE has a picture of a VE8 body on their or someone else's hyper can you please link/host/post it please! I'm trying to decide whether to do mudguards or the VE8 shell and I need to see the vertical clearance for the battery with it.
DanielC. is offline
Old 07-27-2010, 03:56 PM
  #2035
jhautz's Avatar
Trader Rating: 86 (100%+)
I was running a JR9100T serov in my 1/8 buggy using the MMP and never had a single issue with it. Transponder never had an issue or anything. never ran a cap in the Rx either. A buddy of mine was running his MMP in a 1/8 buggy and had nothing but problems with the PT and the Rx cutting out untill he put an external BEC on it. He was using a much more reasonable servo on his also. Very strange that some seem to have an issue with the internal BEC on the MMp and others do not.
jhautz is offline
Old 07-27-2010, 05:30 PM
  #2036
DanielC.'s Avatar
What radio system are you using?
DanielC. is offline
Old 07-27-2010, 06:54 PM
  #2037
HH
HH's Avatar
Default Hyper 9e with a Ve8 body
Thats good to know... what BEC have you found to be the best for this type of application?
I've attached a couple pics of my Hyper 9e with a Ve8 body, it fits perfect.
This car also has Tekno mudguards installed.
HH
Attached Thumbnails HoBao Hyper 9E thread-h9-ve8-18e.jpg   HoBao Hyper 9E thread-h9-ve8-1e.jpg
HH is offline
Old 07-27-2010, 06:56 PM
  #2038
Tech Legend
Cain's Avatar
Trader Rating: 268 (100%+)
main thing about the VE8 body is to confirm your trim lines before cutting.
Cain is offline
Old 07-27-2010, 07:00 PM
  #2039
Jube's Avatar
Trader Rating: 43 (100%+)
Shano, on the RX8 thread you stated you were running a 46T spur. Is this correct? If so how and what manufacturer? Thanks
Jube is offline
Old 07-27-2010, 07:06 PM
  #2040
what about 4cell on the ve8 body. I know the stock body my 4cell wont allow the body to sit perfect.
freon is offline
