HoBao Hyper 9E thread >
Old 05-13-2010, 07:23 PM
  #1486
Trader Rating: 53 (100%+)
4s batteries that are know to fit or demensions ?...anyone
rkhess is offline
Old 05-13-2010, 07:42 PM
  #1487
xDaRReLLx87's Avatar
changing the shock oil to 40-60wt range with gray stock springs
with some bump stops prevent you from bending dogbones ever again
xDaRReLLx87 is offline
Old 05-13-2010, 07:44 PM
  #1488
My stuff hasn't arrived yet but I ordered these because they are supposed to fit good..http://hobbyking.com/hobbyking/store..._hardcase_pack
sickwitit is offline
Old 05-13-2010, 07:50 PM
  #1489
What are you guys using for bump stops?
Old 05-13-2010, 07:55 PM
  #1490
tschenck's Avatar
Trader Rating: 110 (100%+)
Those fit fine. I was running one until I went to an ip5400 to get a little more run time. Still kept the hobbyking as a spare for now though.
tschenck is offline
Old 05-13-2010, 07:58 PM
  #1491
How much run time were you getting on that Turnigy before you switched?
Old 05-13-2010, 08:05 PM
  #1492
I tried using PC rubber dampners for fans and fuel tubing, but this really doesn't do too much, found the oil dampening to work best, least on this car
Old 05-13-2010, 08:14 PM
  #1493
Do you mean the thicker oil worked best to save the dogbones?
Old 05-13-2010, 08:30 PM
  #1494
In my opinion, yes, as I have only bent one and hammered it back straight
and it still is working
Old 05-13-2010, 08:50 PM
  #1495
reracer's Avatar
You should not need them. But you should double check to make sure that the dog bones don't reach their max angle before the shock bottoms out.
Anything over 40wt oil in the shocks is too thick for racing. The stock grey springs are also too stiff for racing. Try the blues or the whit
http://www.nitrohouse.com/catalog/ar...articles_id=24
reracer is offline
Old 05-13-2010, 09:00 PM
  #1496
Did you drill out the pistons like it shows in that nitrohouse setup?
Old 05-13-2010, 09:08 PM
  #1497
reracer's Avatar
I run the jammin 16mm shocks, so my shock setup is different. But if you plan on racing I would start with the setup from Nitrohouse.
reracer is offline
Old 05-14-2010, 12:55 AM
  #1498
Registered User
Trader Rating: 8 (83%+)
Originally Posted by snrscion View Post
Sure Brandon we can collaborate on something.
i feel expensive mod comming on better be carefull brandon may want his commission
shano83 is offline
Old 05-14-2010, 04:34 AM
  #1499
This depends on your shock angles
Old 05-14-2010, 05:47 PM
  #1500
Registered User
Snr any chance you could help me out with a carbon firbre front brace like brandons.I have started my conversion using the standard 9e engine mount so im gonna be looking for somewhere or someone to produce me a front brace.
Cheers
shano83 is offline
