Old 03-29-2009, 08:39 PM   #1
Default Mamba Monster 2650 on a Losi 8ight ??
I have a MM 2650 setup on my 8ight and this thing is ballistic fast. That would be cool for bashing bust for racing it is uncontrollable. What are the best settings for this motor combo to tone it down? I have the timing set to normal with punch control @ medium and I'm running a DX3R radio if that make a difference.
Thanks for the help
xman is offline   Reply With Quote
Old 03-29-2009, 08:54 PM   #2
xDaRReLLx87's Avatar
65% as max throttle, still faster than O.S. V spec II
Use the Castle Link software
Hyper 9E 2000KV T8/RX8- 4S Turnigy 4500 mah
Ko ProPo EX-1 UR 2.4 ghz, Hitec-7950TH
xDaRReLLx87 is offline   Reply With Quote
Old 03-29-2009, 09:03 PM   #3
Trader Rating: 53 (100%+)
Send a message via AIM to nv529
quickest fix would be to turn your EPA down on the throttle side
Nick Vasquez
Tekin | Reilly Paint | Dirt Burner Racing | RC Clubhouse| Washtenaw RC Raceway | TARCAR | The Track
nv529 is offline   Reply With Quote
Old 03-29-2009, 09:13 PM   #4
Trader Rating: 254 (100%+)
Bad idea according to Castle this will cause the system to run hotter than normal.
I run this motor in my Caster and I have my punch control at 80% my start power on low and my timing set at the lowest and it is running well and easy to control for me.
92 vert is offline   Reply With Quote
Old 03-29-2009, 09:29 PM   #5
really?? thats news to me! I've been doing this with my 10th scale stuff for years without problems it seems to be the quickest easy fix while on the track. I wonder what makes it run hotter? I'm going to try it out on my mmm/2200kv and see if i get any temp differences
Nick Vasquez
Old 03-29-2009, 09:40 PM   #6
The esc works harder at partial throttle which is what you are doing by turning down the end points.
This is discussed on the Castle site under the frequently asked question section.This may not be such a issue on the lower voltage 10th scale systems.
Losi 1/8 8ight E 4wd Thread tyhodge07 Electric Off-Road 8898 11-17-2015 06:31 PM
Castle Creation's 1/8 Mamba Monster & Brushless Motors. Thoughts Opinions Suggestions tdeal823 Electric Off-Road 330 02-15-2011 08:37 PM
Losi + Mamba Monster questions mwiley Electric Off-Road 21 10-02-2010 10:37 PM
Question for the 1/8 scale electric guys schultztec Electric Off-Road 28 02-16-2009 10:12 AM
