Old 03-27-2009, 10:55 PM   #1
Trader Rating: 11 (92%+)
Default Castle Link
I was just trying to download the software from castles website, do i need the cd or something for it to work because for some reason it keeps saying i dont have a program running or something, im using windows vista, oh and btw i dont have the cd thats why im asking .
And also, will the mamba monster run without the castle link, like the instructions say quick programiing guide.
Thanks,
Mike
Team Losi:
XXX-CR w/ LRP Sphere 7.5
Brushless 8ight w/ Mamba Monster v3
losiracer18 is offline   Reply With Quote
Old 03-27-2009, 11:06 PM   #2
No workie w/POS vista
Hot Bodies D8
B44
T4
RC10 gt2
SC10
backyardracer is offline   Reply With Quote
Old 03-27-2009, 11:37 PM   #3
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
Mine works fine with Vista. Did you try the other instructions on the Castle site when installing with Vista?
Dan is offline   Reply With Quote
Old 03-27-2009, 11:56 PM   #4
vista 32 bit or vista 64 bit? 4mo. ago when I got this comp. none of the castle software would work (64 bit).
Hot Bodies D8
B44
T4
RC10 gt2
SC10
Old 03-28-2009, 12:21 AM   #5
actually downloaded it now, just had to hit run as adminisrator
Team Losi:
Old 03-28-2009, 04:06 AM   #6
losi_racer's Avatar
Trader Rating: 25 (100%+)
yup, i was just about to say. on vista you MUST download it as the administrator
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 03-28-2009, 04:16 AM   #7
drperry's Avatar
Send a message via AIM to drperry Send a message via MSN to drperry Send a message via Yahoo to drperry
The castle link software works on 64 bit vista, EXCEPT with the Mamba Max.
You can only program via the castle link adapter, which does NOT work with the Mamba Max.
And as I never get an answer as to if it will ever be supported on 64 bit windows, I'm going to have to say that it most likely never will be.
RC18MT - Tekin FX/Stock motor
Yokomo MR-4TC SD CM Novak GTB/LRP X-11 13.5 brushless
E-Jato - Diff still unloads in corners, with 100k weight oil in it!
drperry is offline   Reply With Quote
Old 03-28-2009, 05:45 AM   #8
yeah, i have the mamba monster so i should be ok, i run lrp on my 1/10 scale stuff but im beggining to like the CC stuff do i have to program the mmv3 before i even turn it on?
and dumb question, does anyone have like a diagram for wiring up connectors for 2 2s lipos to the esc? haha
Team Losi:
Old 03-28-2009, 06:25 AM   #9
Dan
Dan's Avatar
No, you don't have to. The Castlelink program is very easy to use. Just plug it into the computer with the USB and the program will detect it. And you can adjust all settings on the on-screen menu.
Old 03-28-2009, 06:37 AM   #10
xDaRReLLx87's Avatar
Not all the time; If you have a CC Bec voltage regulator you have to connect the battery then turn esc for the program to recognize it. The CC Bec is almost mandatory for any Spektrum 2.4ghz
Hyper 9E 2000KV T8/RX8- 4S Turnigy 4500 mah
Ko ProPo EX-1 UR 2.4 ghz, Hitec-7950TH
xDaRReLLx87 is offline   Reply With Quote
Old 03-28-2009, 07:25 AM   #11
drperry's Avatar
Is the BEC of the MMM too low for the 2.4ghz stuff?
If I remember the manual right, the Spektrum RX is good for 2S unregulated LiPo...
Then again, the speed control will be happier with the BEC disconnected.
Old 03-28-2009, 07:32 AM   #12
No, the CC BEC allows you to put the receiver and servo from 0-10v
I personally use 6.9V as its the best happy medium between 6.8V and 7.2V
for the lifetime of your "servo motor" 6.8-6.9 is the best range for that.
There's nothing wrong with having to plug esc on plug battery on then turn esc on, I actually prefer this method. Keeps the Spektrum receiver from resetting on you and also makes your servo faster, win win situation.
Old 03-28-2009, 09:29 AM   #13
thanks for the help fellas, i begin my 8ight project today
Team Losi:
Old 03-28-2009, 10:12 AM   #14
drperry's Avatar
Unless you're like me and have an unregulated LiPo safe servo
Old 03-28-2009, 10:48 AM   #15
Trader Rating: 21 (100%+)
No, you don't but be aware that the lvc is set off when it wakes up. I just went thru this with a v3 and a Sidewinder. For wiring look at this - should be ablr to build one from the pic - thats how I did mine.
http://www.maxamps.com/Deans-Series-Adapter.htm
Duster_360 is offline   Reply With Quote
Castle Creations Mamba/MM/MMM FACTORY Q&A thread! Joe Ford Team and Company Discussions 2371 08-07-2017 11:37 AM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
HB D8 Electric, Feigao 8xl, Mamba Monster Twiztid Rock R/C Items: For Sale/Trade 8 06-12-2009 06:28 PM
*********MAMBA MAX, CC BEC AND CASTLE LINK BRAND NEW!!!!********** cola R/C Items: For Sale/Trade 7 05-01-2008 11:09 PM
how to use castle link mojo_23 Electric Off-Road 13 03-14-2008 09:37 PM
