Old 11-30-2003, 08:15 AM   #1
Send a message via AIM to Vanderslice
Default 27mhz or 75mhz?
what are the pros and cons of each??
Vanderslice is offline   Reply With Quote
Old 11-30-2003, 08:43 AM   #2
alucard13's Avatar
As posted by Gee-Dub in the Electric forum from your same question:
"27 - pro :has wider band spacing (.05mhz) vs .02mhz for 75 between channels. means you're less likely to get radio hits from poorly tuned radios.
con: only 6 'legal' (non-HAM) channels on that band. too many people on that band, and you're gonna be stuck waiting for a frequency clip all the time.
75 - pro: 30 channels means you're more likely to have an open frequency clip.
con: narrower bandwidth spacing (hardly ever an issue though)
best solution is 75 band synthed'. been running this setup for about 6-8 months, will never go back."
alucard13 is offline   Reply With Quote
Old 11-30-2003, 10:08 AM   #3
Trader Rating: 70 (100%+)
Send a message via AIM to TexRacer
If you decide to go Synth.Stay away from the FULL novak setup.It's been tested and Crystals are still stronger signal wise.
If you decide on this setup go with the Novak Module if it can be used on your pick of radio(M8) and use a JR reciever.I have heard ALOT and I mean ALOT of nightmars with the novak,novak system.
*****Look me up on Ebay. I will have alot of stuff going up as 7/7/2016. User name is Dalracer.**** This is going to be a BIG ONE!!!!!!
Just wanted to say Thanks to RcTech for all these years of Great Information.
TexRacer is offline   Reply With Quote
Old 11-30-2003, 03:57 PM   #4
what are these so called nightmares?
Old 11-30-2003, 05:30 PM   #5
Glitching.The Signal Strength isnt as good as crystals.
Now if you decide to go with 27mhz with the new module that novak came out with on 27 and a novak XXtra on 27 it may work better.But the 75 one being closer together I have seen some expensive nightmare's and had some of my own on the 75MHZ XXtra and module.Plus if you look around on some of the message boards you will see complaints about them.
Old 12-01-2003, 12:38 PM   #6
I got a Novak XXtra receiver from a friend who was getting glitches all the time. However, he was getting glitches with every radio he had or tried including dual conversion receivers so I figured "why not" try it.
I installed the Rx in my TC3 and never once experienced a glitch of any kind while using my Hitec Lynx 3D with the Spectra module (synthisizer). I switched radios to the Futaba 3PK and still never had a glitch yet. My friend is still looking for a radio that doesn't glitch and is using a KO Mars R (he'll never find one because the problems he had weren't radio related).
Currently, I'm using the Futaba HRS to see if it responded any faster. Unfortunately I must report that if the response was faster then I must have missed it.
AreCee is offline   Reply With Quote
Old 12-01-2003, 09:23 PM   #7
Arecee-On your Mars R or Futaba HRS to respond faster you have to use the factory reciever or the new LRP reciever and DIGITAL servo's.But again it's still hard as hell to tell.lol.
27mhz and 75mhz Bikerbob R/C Items: Wanted to Buy 3 04-09-2006 06:56 PM
WILL SWAP JR XS3 PRO 75MHz TX & RX FOR A 27MHz TX & RX rex222 R/C Items: For Sale/Trade 3 10-11-2005 01:06 AM
FM radios. 27Mhz or 75Mhz jackhammer74 Electric On-Road 9 09-02-2004 01:56 PM
Want to trade 75mhz FM receiver for 27mhz or 27 mhz MX3 for 75 mhz imjonah R/C Items: For Sale/Trade 0 07-02-2004 06:56 AM
Radio choice, 27mhz or 75mhz Cain Electric On-Road 0 05-31-2004 08:21 AM
